SATC - Retro fit. - Page 2 - Air-Con / Heating (Mk1/Mk2 Mondeo) - TalkFord.com
SATC - Retro fit.
72 replies to this topic
#11 rusdee
rusdee
    still lost
  • 1372 posts
Posted 07 February 2006 - 10:52 PM
this is sounding like a big job as you know the car port is always there if you need it :L just dont put on the st bumper on :naughty: whilst its there
it has been said that the purpose of my life
is to serve as a WARNING to others
saab 2.2tid vector estate
astra gte 16v rally car
2.0 yreg capri
#12 Cool_dood
Cool_dood
    Dude
  • 1941 posts
Posted 07 February 2006 - 10:54 PM
:L Nice one :D
If all goes to Plan, im going Essex on Monday to remove a FULL Ghia X dash loom, so that should help with all the wiring up :L
Mondeo Mk4 1.8tdci Zetec "Sport"
#13 rusdee
rusdee
    still lost
  • 1372 posts
Posted 07 February 2006 - 11:01 PM
essex!!
2.0 yreg capri
#14 Cool_dood
Cool_dood
    Dude
  • 1941 posts
Posted 07 February 2006 - 11:22 PM
Yep. 600mile round trip :(
Going down tomorrow now :loopy:
#15 Cool_dood
Cool_dood
    Dude
  • 1941 posts
Posted 08 February 2006 - 06:31 PM
Ok guys. Just to update any one that is intrested. I have got a Ghia X loom that had Satc fitted as standard.
All i needs now is to know were to connect the outside temp sensor to on the SATC. I think thats it, unless any one can shed some light on other problems i will encouter? :D
#16 rusdee
rusdee
    still lost
  • 1372 posts
Posted 08 February 2006 - 08:37 PM
could look one mine but i dont know were to look or what it looks like
2.0 yreg capri
#17 L11XXY
L11XXY
  • 3438 posts
Posted 10 February 2006 - 07:05 PM
I Retro fitted mine using 'the disk we shall not mention' that i bought off Ebay. The origonal setup is still in the vehicle as i just unclipped wiring from the corresponding connectors on the CJB and then installed the remainder of the wiring as a standalone loom. If you need any tips for routing the wiring through the bulkhead use the search function. The vacuum resevoir that you have in your picture will not be required as you already have one in place. You may also have issues fitting the flap motor to the heater casing if you only have manual control on it at the moment. If you already have the WHITE flap motor installed its a POP to fit.
If you have aircon the re circ valve will also be in place. The coolant temp sensor (top of picture in middle) needs to be routed through the bulkhead into the engine bay via the grommet behind the heater matrix.
The only function this serves is to limit the hot air flow through the blowers until the engine has fully warmed up. I have the sensor, in the shed, and have fitted an interior sensor below the floor heating duct. This was taken from a Focus with EATC.
Also, the self test for the SATC is as follows...
Turn SATC to AUTO
Turn Heater direction to screen
Switch on Ignition
Press AC and the RED button together, release, then press the BLUE button. Unit then enters self test and will display any error codes at the end.
The OOA Temp sensor clips in behind the front bumper on the drivers side as you look from the front.
02 ST220,Retro Fitted Touchscreen Nav,Bluetooth, Voice Control,Climate Seats, OEM DVD Entertainment, RSE System, Xenons, Focus Sub Lighting
Ford IDS Services available - Denso Touchscreen Sat Nav Repair & Diagnostics -
NOW WITH JAGUAR SDD DIAGNOSTICS ALSO
Bluetooth Diagnostics - Electrical Upgrades & Retrofits - Mobile Service may be available
Call Alex on the usual number
07955 406 446 - E Mail [email protected]
UPDATED 25th June 2020
#18 Cool_dood
Cool_dood
    Dude
  • 1941 posts
Posted 11 February 2006 - 09:34 PM
Thank you. Im sure i shall have pleanty more questions to ask in a few weeks :L
#19 V6 Panther
V6 Panther
    MEG Commander
  • 1162 posts
Posted 14 February 2006 - 11:22 AM
I got a full Ghia x loom yesterday so i'll be joining you m8. ;)
The only thing i need to complete is the coolant temp sensor.
Is it me or can't i see a sunload sensor in your pic?
I'll keep you informed on progress with pics if possible as i'm hoping to do it this week. :L
2003(03) Very high spec ST220 in Performance Blue
Previous Mondys..........
2000(X) ST200 LTD Saloon
1997(P) V6 Ghia X Saloon in Dark Aubergine
1998(S) ST24 Hatchback in State Blue
1994(M) V6 Ghia Hatchback in Ash Black
1994(L) 2Litre Si Hatchback in Ash Black
#20 Cool_dood
Cool_dood
    Dude
  • 1941 posts
Posted 15 February 2006 - 12:29 AM
Its there trust me :L
I managed to understand the wiring diagram i posted, and figured out what 3 wires i need to splice :L
V6Panther, you say you got your Ghia X loom, does it have this connector next to the electric wing mirror connector?
Also, Ill be taking picis too, so if you want them posting to you, and perhaps put a "how to" together? :L
