Windshield demist when<4 - Focus Mk4 Electrical - TalkFord.com
2 replies to this topic
#1 dzincha
dzincha
  • 2 posts
  • Vehicle Driven:Focus
  • Name:Dzintars
Posted 04 May 2021 - 05:26 AM
Is it heating electrical windows at low outside temperatures?
focus 2015 made noticed that it does it when below 4 degrees and whenndoing regen. Is it same on mk4 focus?
Does ford mk4 diesel versions has electrical preheater, like electrical hot air heater?(vw has it from 2012 i believe in their tdi and others as well).
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 04 May 2021 - 11:36 AM
Not sure on the later Focus but on the Mondeo only the diesels switched the heated
windscreen on automatically.  Quite often though the windows would be clear when
it switched on so just draining the battery.
Some cars have an electrical pre-heater but not all. Use the ETIS link below to see
your cars build spec (you need to register to see the full spec).
Or send me your reg/VIN  and i will send you the results.
Dash may alert you when the heater is on/off?
2015?   MK4 2018 onwards??  Wrong year or wrong MK?
#3 dzincha
dzincha
  • 2 posts
  • Name:Dzintars
Posted 04 May 2021 - 02:43 PM
I got 2015 focus 1.5 tdci, which had no pre heater and also did back window heti g when<4C.
wondering if new focus mk4 (2018+) is doing same.
Reply to this topic
