Honda engine - Off-Topic - TalkFord.com
Honda engine
6 replies to this topic
#1 Rekusu
Rekusu
  • 2163 posts
  • Vehicle Driven:Mk3 Mondeo, TDCI
Posted 29 April 2021 - 05:42 PM
What ho one and all,
Yes, it is a Honda engine, but a small garden, 4 stroke engine.  In particular, the popular GX25 sitting on a rotavator/tiller.
It is a couple of year old and does not get excessive use.  It has gradually, become more difficult to start until recently, it will not start at all.  So a Google search reveals the most probable cause is the carb and a  refurb kit is not expensive.  Bought a Chinese number, complete with new spark plug and ignition coil.
Cleaned the carb, fitted the other bits and still, it will not start.  Almost does, but not quite.
Went the next stage and bought a new carb which I fitted today.  Again, tries to start but generally, zilch.  On a couple of occasions, it has run fro around 5 seconds,then dies.  All the fuel lines have been blown through and are clear but it almost feels like fuel starvation.
I have checked the spark plug and it sparks.  Finger over the spark port and there is compression, but not as much as I would have expected.  Removed the exhaust to check and that is clear.  Again, finger over the port and 'kinda' back-fired as I guess I was blocking the exit!  But certainly compression.
Removed the valve cover to check that the timing belt is in place and all looks good with valves doing what they should.
Tried again, and this time, some kind of back compression almost broke my wrist!!!  There is now a lot of compression that is preventing any sort of turn-over.  Since I did not fiddle with anything mechanical (valves or timing belt) don't know what has happened.
But given that it is a pretty simple single cylinder engine, I don't know what else could be out of wack that it will not start.  I can only think the timing belt has slipped, but that does seem unlikely.
So I hope the greater mechanical minds on this forum will be able to offer some advice.
Thanks and toodle pip
What if the Hokey Cokey IS what it's all about?
#2 stonekeeper
stonekeeper
    TF regular
  • 799 posts
  • Vehicle Driven:Mondeo titanium x
  • Name:Mark
Posted 29 April 2021 - 07:47 PM
https://engines.hond...leshooting-tips
#3 Rekusu
Rekusu
  • 2163 posts
Posted 29 April 2021 - 08:52 PM
Thanks for the link.   Have not seen that page before but similar and all roads lead to the 'Take it to a Honda rip-u-off dealer.  had a chat with one and they want to chat a mere £40 (plus VAT) just to have a look and diagnose the problem.  Of course, they would not strip it to see why it will not start so I imagine they would tell me what I already know.
I can only see one other reason that I am putting off checking and that is the timing belt has slipped a notch.  But that does imply stripping the engine to check and most likely, find the timing is fine.
#4 stonekeeper
stonekeeper
    TF regular
  • 799 posts
  • Name:Mark
Posted 29 April 2021 - 09:14 PM
https://arbtalk.co.u...913-honda-gx25/
#5 Rekusu
Rekusu
  • 2163 posts
Posted 30 April 2021 - 06:40 AM
Thanks for the link.  One I had not previously found.
I did wonder about the tank vent and have dismantled the cap, but cannot see any vents to the outside world.  My other small motors (strimmer, mower, leaf blower) all have small holes in the cap but not the Honda.
There is plenty of oil, there is no oil level switch in the crankcase, plenty of spark.  I blew through the various fuel lines and they are all clear.  Not too many options left.
The card / head gasket is a possibility but strangely, none of the carb repair kits supply this.
#6 stonekeeper
stonekeeper
    TF regular
  • 799 posts
  • Name:Mark
Posted 30 April 2021 - 09:40 AM
Have you tried "Easy start" or similar through the air intake to see if it's fuel related?
The only other consistant thing i keep seeing in my searches on it are "Stale fuel"?
Edited by stonekeeper, 30 April 2021 - 09:44 AM.
  • TreborB likes this
#7 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 30 April 2021 - 10:09 AM
Had a strimmer where someone managed to fill it with diesel.
Must have been some fuel in it already because it still had a strong
petrol smell.
9 user(s) are reading this topic
0 members, 9 guests, 0 anonymous users
