Speedometer problem.... - Mechanical (Ka Mk1) - TalkFord.com
2 replies to this topic
#1 jessica-Michelle
jessica-Michelle
  • 2 posts
  • Vehicle Driven:Ford Ka
  • Name:Jessica Michelle
Posted 28 April 2021 - 12:00 AM
Hi Guys and Gals,
I have a problem. My speedometer has stopped working.
Took it to a friend of my boyfriend who plugged in some machine and said one of the ABS sensors had conked out and that could be causing the problem but he couldn't say which one as the machine to do that costs about a billion pounds. Anyway, took it to a proper garage and he said it was probably the worm gear in the gearbox had stripped and yet another garage said that was rubbish as it was electronic so.......HELP.....PLEASE. It may be old but it's my baby - lol.
So, anybody have any ideas as to how the thing works? Is it electronic or mechanical and what could be the problem? Oh, the fuse is ok; that was checked.
Any help gratefully accepted.
Luv'n'hugs
x
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 28 April 2021 - 12:08 PM
Have you checked the speedo to see if its cable driven or electronic only?
A sub £20 OBD reader should tell you which sensor. I have a dongle that cost £4
that would do the job but buying them is hit and miss.
£20 will get one that will do the job is its an ABS sensor issue.
But useless if its cable driven.
What year/spec etc. is the car?
What else does not work or what else is causing an issue?  ABS light on?
Does the ABS light work is the ABS working?
#3 jessica-Michelle
jessica-Michelle
  • 2 posts
Posted 28 April 2021 - 01:46 PM
Oh, thanks for your reply.
Sorry, forgot to mention so many things you have pinpointed. I'm new to all this.
The car is a Ford Ka, 2006, Very basic. 1.3cc
Yes, the ABS light is on but will that effect the speedometer?
Again, thank you for your time.
