windscreen washers not working - Electrical (Mk3 Mondeo) - TalkFord.com
mk3 2006
4 replies to this topic
#1 pk.1600e
pk.1600e
  • 2 posts
  • Vehicle Driven:mk3 mondeo
  • Name:john nelson
Posted 23 April 2021 - 04:24 PM
hi my windscreen washers are not working have checked the motor and its working but when testing for power at the plug when the button is press in the light on my test lamp goes out when its realest in goes on and thats on both wires on the plug any help please
#2 dojj
dojj
    Resident Wrestling Legend
  • 3959 posts
Posted 23 April 2021 - 09:01 PM
you'll have to remove the pump to check it's not blocked
if you are sourcing a replacement pump, you also need to make sure it's got the same connectors as preface and facelift used different shaped plugs on the same motor body
it's very difficult though so make sure you can get i high enough in the air, you may need to remove bits of trim to get it it underneath the car too as was the case with mine, i eventually had to remove the bumper too ;(
mk3 mondeo ghia x estate 2.0 auto with:
362mm 6 pot ap stoppers lurking behind some 8 x 18 comps
tv fitted to facelifted dash + headrest screens for both kids
full st kit + powerfolds w/puddlelights with jp stainless exhaust
shonky n/s/f rattle fixed by totd whoopie!
most of the chrome bits done
#3 pk.1600e
pk.1600e
  • 2 posts
  • Name:john nelson
Posted 24 April 2021 - 12:58 PM
i have the pump out and it works fine but not when its plug in and when i put my test lamp on the plug both side off the plug light up and when you push the button its goes out on both off them
#4 nicam49
nicam49
  • Gold Member
  • 4293 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Nick
Posted 24 April 2021 - 02:48 PM
How have you got your test lamp connected... and is it a tungsten bulb or an led.
Do you have a multimeter you can use instead?
You should connect the test lamp to both sides of the plug at the same time.
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 25 April 2021 - 11:51 AM
Its possible to get a voltage that is not powerful enough to activate the pump.
I was testing some towbar wiring some years back, LED tester showed the cars
electrics all good and it showed the caravan electrics all good but still no brake
lights.
Turned out the 12v detected on the brake wire dropped to just to almost nothing when
the brakes were applied.
Stripped the brake connection off in the boot and made a better connection and it was
all good.
Check the voltage when the pump is activated.  Also its possible for the pump to spin and
no water comes out. Could be a blocked filter or just a failed pump.
