ABS Module Programming - Electrical (Mk4 Mondeo) - TalkFord.com
abs module
3 replies to this topic
#1 tomi_89
tomi_89
  • 19 posts
  • Vehicle Driven:Ford Mondeo
  • Name:Tomislav
Posted 23 April 2021 - 04:20 AM
Hi, I need some help regarding Abs module programing in the car. What i presume that in Forscan i need load old data and write in new one, but the pump is different model from old one (from ab to fb). The As build file that i can load in new one and simplicity complete the task is not posible. The as build file can download but file is empty. Not information in section as abs and ect...
#2 Graham24
Graham24
  • 418 posts
Posted 23 April 2021 - 08:00 AM
The ABS module has to be programmed in via Ford’s IDS system as it is part of the immobiliser system.
#3 go4it
go4it
  • 408 posts
  • Vehicle Driven:Mondeo
  • Name:Oli
Posted 27 April 2021 - 05:32 PM
If you habe a make before 2010, you can program it yourself with Forscan. PATS algo changed with FL 9/2010 onwards, where IDS is needed.
#4 tomi_89
tomi_89
  • 19 posts
  • Name:Tomislav
Posted 28 April 2021 - 06:21 AM
Yes its before 2010. I have forscan extended license but problem isas build file. I write new topic about my problem. I dont know its safe to upload current data from old abs? I Change 8g9n2c405ab to 7g9n2c405fb. Diferrent revision and lines where is vin is contain numbers and leters so unable to convert to asci vin
Also tagged with one or more of these keywords: abs, module
