Front anti-roll bar removal - Suspension / Wheels / Brakes / Steering (Mk3 Mondeo) - TalkFord.com
3 replies to this topic
#1 Milk Cat
Milk Cat
    Kitten
  • 166 posts
  • Vehicle Driven:2.0l TDCi Ghia ('04)
Posted 22 April 2021 - 09:26 AM
During wishbone removal I suspect I've bent the front anti-roll bar. Not the anti-roll bar links to clarify, I mean the bar that passes from nearside to offside through the vehicle. After the four 13mm bolts holding the bar to the subframe are removed, is this bar removable by lowering the subframe at the rear only?
#2 ST56
ST56
    Clever cloggs
  • 2241 posts
Posted 22 April 2021 - 12:15 PM
Hi
I would be surprised if you actually bent this bar as material allows for considerable deflection and will then spring back to shape. What makes you suspect it is bent.
Try disconnecting one end of drop link, sit car on flat ground then see if end aligns with end of bar.
Peter
Previously Mondeo MK2 ST200.
Previously Sierra XR4x4.
#3 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 22 April 2021 - 02:49 PM
Think the only time i have seen them bent is where someone used a jack under
it or attached a towrope to the centre section.
I have used a 4ft+ jack handle under the subframe and levered them downwards
with no ill effects.
Its essentially a spring so fairly robust.
#4 Milk Cat
Milk Cat
    Kitten
  • 166 posts
Posted 22 April 2021 - 03:51 PM
Think the only time i have seen them bent is where someone used a jack under it
Embarassingly - yes. That's how I bent it.
