Turbo replacement (parts needed) - Diesel Engines (Mk4 Mondeo) - TalkFord.com
6 replies to this topic
#1 Ddleeds
Ddleeds
  • 20 posts
  • Vehicle Driven:Ford Mondeo
Posted 17 April 2021 - 05:49 PM
The missus car keeps going in to limp mode.its a MK4 2.0 tdci 140 0n 2010 plate. Iv had it on forscan and it said actuator stuck. So I jacked it up and freed it off with a pry bar and ran some turbo cleaner through it. Was fine for a month now keeps coming back more frequently. So iv ordered a turbo and a fitting gaskets. Has the metal gasket with the 3 stud holes the one for the oil feed and 2 cooper washers on the looks of it.
I was wondering what else I need to replace in Haynes it mentions replacing the banjo bolt and filter. Do I need to do this or just clean it out break cleaner.
Would like any advice on anything else I need to order with part numbers would be great help
Also any tips from any one else already changed a turbo already on one of these
Thanks in advance
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 18 April 2021 - 12:43 AM
If you do not replace it make sure you clean it and add some threadlock to
help it seal.  Possible risk of an oil leak if you reuse them, if its all clean and
no gouges from the washers then new washers should fill the gaps.
Filter is sold on its own, almost £20 but looks like it will be very hard to clean
if at all.  Looks like a woven mesh from the pictures.
#3 Ddleeds
Ddleeds
  • 20 posts
Posted 18 April 2021 - 08:39 AM
Do you know the part number so I can order one? Thanks
#4 Ddleeds
Ddleeds
  • 20 posts
Posted 18 April 2021 - 08:44 AM
1336616-FORD
1337174-FORD I found these 2 not 100% shure there the correct ones though
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 20 April 2021 - 04:43 AM
https://ford.7zap.com/en/car/39/
or
http://catcar.info/f...DA3LTIwMTQifQ==
#6 Squirt
Squirt
    I might like Fords
  • 1683 posts
Posted 20 April 2021 - 07:42 PM
If replacing the turbo, I would replace the oil feed pipe as a lot of turbo suppliers like to reject a warranty claim due to incorrect fitting. Banjo bolt filter also a good idea..
If it’s a Euro 5 engine, (facelift engine) then good luck fitting it as that’s abit of a pain in the rear...
Edited by Squirt, 20 April 2021 - 07:44 PM.
Blue Oval Vehicle Services
Cheltenham's Ford Specialist
www.blueovalvehicleservices.co.uk
#7 Ddleeds
Ddleeds
  • 20 posts
Posted 24 April 2021 - 09:20 PM
I ordered the bits I put the codes of. I spent today just getting the turbo off. It's a MK4 the older Citroen/Peugeot engine and it's a right pain in the rear aswell feel like iv.been at the gym. Tomorrow the new turbo is going on
