Smoke on start - Diesel Engines (Mondeo Mk3) - TalkFord.com
Smoke on start
injectors smoke
2 replies to this topic
#1 Hugginjp
Hugginjp
  • 1 posts
  • Vehicle Driven:Mondeo mk3 2.0 TDCI
  • Name:Jacob Huggins
Posted 16 April 2021 - 11:15 AM
Hi guys!!
I’ve recently removed all my injectors, had them ultrasonically cleaned, new seals and pipes refitted in a different order and reprogramed. when running normally this has had a wonderful effect, the engine is quieter and smoother, ignoring the problem I am having with the aux belt. However, on a cold start up (if the engine is warm already this doesn’t happen) the engine is rough idling at 1000 instead of 700-750 and it makes a huge amount of smoke (white) before settling down once it’s warm.
Is this just the engine still learning the new injectors and the problem will solve itself over time (I’ve only had 5 or so starts as I’ve gone back to uni and don’t drive too often) or is this something that’s wrong? if it is where do I start looking, I plan to clean the MAF this afternoon to see if that makes a difference?
Thanks to anyone in advance,
I'm an engineering student (which translates to me thinking I’m good at this but actually having no clue)
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29203 posts
Posted 16 April 2021 - 03:57 PM
It should not have white smoke even when learning.
leakoff test?
#3 DavieWeegie
DavieWeegie
    Mondeo Lover
  • 737 posts
  • Vehicle Driven:Mondeo ST TDCI 2005
  • Name:David
Posted 16 April 2021 - 04:51 PM
sounds like the problem I had when I decided to recode injectors that had been in for a long time.
injectors when new have c2i code thats programed for their fuel delivery at different operations and they are tested for spray patterns, this c2i code is then input into the ECU. Through wear and tear the injector drifts further and further away from this original code and most times the ECU can compensate for it on the fly but sometimes its drifted too far and it cant compensate anymore.
This is what happened with mine, I cleaned the injectors put them back in and input the codes again, but had loads of white smoke and rough idle when cold that got better when it had warmed up, I ended up buying 4 reconditioned injectors from PF Jones and sending my old ones back for discount.
My moral of the story is sometimes its better just leaving what you've got than try clean things yourself, especially something as temperamental as Mondeo injectors.
Edited by DavieWeegie, 16 April 2021 - 04:51 PM.
Performance Blue Mondeo ST TDCI 2005
Also tagged with one or more of these keywords: injectors, smoke
