Sync3 updates Errors - Ford SYNC Forum - TalkFord.com
updates errors
2 replies to this topic
#1 bungiroger
bungiroger
  • 2 posts
  • Vehicle Driven:ford fiesta st line
  • Name:bungiroger
Posted 14 April 2021 - 02:05 PM
I downloaded the latest sync3 map updates for my 2020 fiesta & it came down with the DONTINDX.MSA file missing.
 I updated the vehicle then recieved Error code: PKG_ERR03.
 Has anybody an idea what this is or how to overcome it?
  I have done this 3 times now.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29213 posts
Posted 14 April 2021 - 04:57 PM
What file system is the memory stick/card formatted with?
What did you use to unzip the main file and what files/folders
are there on the storage now?
USB 2 or 3?  read/write speed?
Scanned all the files in the original package for compression errors?
#3 musketoon1870
musketoon1870
  • 1 posts
  • Vehicle Driven:Ford Focus
  • Name:Oliver Wakefield
Posted 17 April 2021 - 09:18 AM
I had a similar problem - i had to make a stop and it switched off during update - causing the above error. Now i think it is installed but it didn't spit out a log file. This is probably because i had the usb formatted as fat32 rather than exfat. I've tried to use the diagnostic tool "Interrogator_AB" to get the log file but no results. Any help would be appreciated with getting the log file out.
