Facelift Mca retrofit - In-Car Entertainment (Mk4 Mondeo) - TalkFord.com
3 replies to this topic
#1 Richda42
Richda42
  • 2 posts
  • Vehicle Driven:Mondeo 2.0 tdci
  • Name:Richard Adams
Posted 11 April 2021 - 06:30 AM
Hi, I have a 2010 facefilt with the basic 6000 cd head unit and have bought an mca to fit. The seller had sent photos of it working prior to removal but when I connect it in it does not power up. If have changed the configuration with Forscan. Is it likely that the quadlock connections are different?
Edited by Richda42, 11 April 2021 - 06:31 AM.
#2 alsmondeo
alsmondeo
  • 89 posts
  • Vehicle Driven:Mk4 2.0 Ecoboost
Posted 11 April 2021 - 06:31 PM
I also have a mk4 facelift and did the same retrofit from basic 6000CD to MCA.
Did you change the audio loop connector? It's behind/above the glovebox. You need 8G9T-14N000-BB, your car will have something different.
I just changed the loop and the car configuration and everything worked fine.
#3 Richda42
Richda42
  • 2 posts
Posted 11 April 2021 - 07:28 PM
Not sure where the quite come from.
I think I may have bought a faulty one. Was checking again today and when it’s turned on the screen goes from black to grey.
Edited by Richda42, 11 April 2021 - 07:33 PM.
#4 go4it
go4it
  • 408 posts
  • Name:Oli
Posted 18 April 2021 - 12:47 PM
Would you make some photos? For me, it seems like the graphicsboards is faulty. When "something" happens after hitting the on-tipper, the high-voltage background may not work. This would look like you described.
I had a suspect... but therefore you need to open the MCA. Separate the front-part am make detail pictures of the graphicsboards, mounted behind the LCD screen.
3 user(s) are reading this topic
0 members, 3 guests, 0 anonymous users
