1.0 Ecoboost power issue - Mechanical (Focus Mk3) - TalkFord.com
4 replies to this topic
#1 kjea5ty
kjea5ty
  • 4 posts
Posted 03 April 2021 - 08:49 AM
Hi all,
Puzzling issue that I’ve had experienced a few times the past couple of months with my 2013 Focus Zetec S 1.0 Ecoboost.
Start the car up and just seems like the turbo has gone “awol”, put my foot down and there’s no sense of spooling/power delivery. Almost seems like it’s in a protective/limp mode but can still get to max 70 (in its own time), but with no alarm on dash.
Can then park up, turn engine off, then go back to it after a while, start up and turbo is present and spools up with good strong power delivery.
Anyone else experienced this or got an idea what it could be?
Engine is completely standard with no modifications on. At 82k miles at mo.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29176 posts
Posted 03 April 2021 - 04:42 PM
Its probably in limp mode. Check for fault codes with an OBDII scanner.
I had an issue on a diesel where there were no fault lights/codes but same get
to 70 but actually went slower if you floored it.  With mine it was a pipe that
popped off.
Obviously mine did not reset by cycling the ignition.
  • kjea5ty likes this
#3 kjea5ty
kjea5ty
  • 4 posts
Posted 03 April 2021 - 04:50 PM
When I get a chance, I want to go try to whip off all the induction pipes and priming pipes for the turbo, checking for splits/wear.
Like I said, it’s just strange not to throw any alarm/faults on the dash.
May have to invest in a obd reader to see if any fault codes are showing more on the depths.
Thanks for the reply
#4 Master-of-none
Master-of-none
    Clever cloggs
  • 1574 posts
  • Vehicle Driven:1.0 125PS Focus Ti
Posted 07 April 2021 - 08:32 AM
Have a look at the turbo recirculation valve, it has a rubber diaphragm that can split.
Unfortunately the diaphragm is not available separately you have to buy the cover as well.
Access is a bit awkward, as it's under the turbo and there is a relatively small gap between the radiator and turbo. It's really only 3 screws and a pipe clip, but be prepared to drop some screws or your tools and have to remove the engine undertray! My tip is to stuff some rags or cardboard to catch dropped items before they fall too far.
Terrible video showing the location (on a Fiesta) and an alternative valve.
Weaselling out of things is important to learn,it's what separates us from the animals Except the weasel
#5 kjea5ty
kjea5ty
  • 4 posts
Posted 07 April 2021 - 04:11 PM
Thanks for the info. I had read up a little about those valves splitting. Uprated versions bout £115 or so I hear.
Hopefully get a chance to take a look next week when I’m off shift.
