Battery goes flat in less than a week - Electrical (Mk3 Mondeo) - TalkFord.com
6 replies to this topic
#1 mondeo df
mondeo df
  • 162 posts
  • Vehicle Driven:MK3 Auto Ghia X 2004
  • Name:Roy
Posted 05 March 2021 - 08:50 PM
2005 Hatch 2.0 petrol auto.
As the title says....Battery goes flat in less than a week.
Last winter the battery kept going flat.
Bought a new one and all was well.
The alternator cooked at the end of last summer. Literally.
I fitted a used alternator and all was well.
Since the weather got colder the battery flat issue returned.
Got the battery swapped under the 5yr warranty.
2 weeks later and dead battery.
The car is only used 2-3 times a week at most. But that's enough to avoid the problem
If it's left for a week it's flat.
Tomorrow I'll stick the ammeter in the supply lines and see if I can tell where the power drain is but wondered if you guy's could tell me the likely causes / suspects.
And... although I'm sure the alternator is doing it's job of charging, could it also be the source of the drain?
Cheers for any advise.
Edited by mondeo df, 05 March 2021 - 08:50 PM.
#2 raynkar
raynkar
    Dash cams, catch 'em out :)
  • 12920 posts
Posted 05 March 2021 - 09:18 PM
What make and type of battery do you have?
Is it a silver calcium type and not a lead acid battery?
#3 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29152 posts
Posted 05 March 2021 - 10:27 PM
Yes alternators can drain the battery if faulty,  boot light staying on
or the map lights etc?
Aftermarket stereo staying active?  Anything plugged into the lighter sockets?
Towbar fitted?
#4 mondeo df
mondeo df
  • 162 posts
  • Name:Roy
Posted 05 March 2021 - 11:04 PM
It's the silver type.
#5 mondeo df
mondeo df
  • 162 posts
  • Name:Roy
Posted 05 March 2021 - 11:05 PM
Towbar fitted?
Yeah, checked the boot light, and all other interior lights. Got the original Ford stereo and unplugged the ciggy lighter.
No towbar.
Has got aftermarket rear parking sensors. Will look at those.
What tests can I do on the alternator?
Edited by mondeo df, 05 March 2021 - 11:07 PM.
#6 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29152 posts
Posted 06 March 2021 - 02:34 AM
You need to check the diodes in the alternator, they normally block the flow in one
direction from the AC output. When they breakdown they allow current to pass
backwards which drains the battery.
Battery/alternator test...  http://www.talkford....test-procedure/
Do that test so we can see if there are any obvious issues.
#7 mondeo df
mondeo df
  • 162 posts
  • Name:Roy
Posted 06 March 2021 - 05:36 PM
OK... found it.
Did all tests as above but nothing showed up.
So... I put the ammeter between the battery live terminal and the live clamp, so any current flowing had to go via the ammeter. Nothing could escape.
Found I had wildly fluctuating current between 25mA and 60mA. Not what I was expecting.
Did the same check on my Mondy (this is the wife's Mondy) and had rock solid 16mA (locked or unlocked)
So, back to the wifes car and I pulled each fuse in turn till the current dropped to a solid 16mA.
A-HA!!! F28.... 20A supplying the ignition switch.
Put the fuse back and pulled the plug off the ignition switch... no change.
Pulled the fuse box out to see if there was any corrosion or a fried spider or worse.... nothing.
According to Haynes there was nothing between F28 and the ignition switch except a 1.5mm red. Nothing else supplied by F28.
So I chopped the cable about 3" from the fuse and 3" from the ignition switch and crimped in a new cable (I used some 1.5mm flex and left it double insulated)
BINGO!!!!!
16mA solid. Everything working as it should.
Without stripping the loom to try to find exactly what and where, I'll never know quite what was going on but at least it's sorted.
Brownie points in the bag and a well earned day down the man cave tomorrow!
I hope this will be useful to somebody some day.
Edited by mondeo df, 06 March 2021 - 05:39 PM.
  • nicam49 and TreborB like this
