Aftermarket DAB in Android head unit - In-Car Entertainment (Mk4 Mondeo) - TalkFord.com
dab aerial android
1 reply to this topic
#1 SoundsDigital
SoundsDigital
  • 399 posts
  • Vehicle Driven:Mondeo TDCi
  • Name:Mark
Posted 02 March 2021 - 06:02 PM
I fitted an Android head unit to mt 2008 Mk4 Zetec a few years ago and have just bought the USB DAB+ adaptor for it. It comes with an aerial that sticks to the windscreen, but I have a heated windscreen.
I understand that the heated windscreen isn't ideal for a windscreen aerial, but would be interested to know if other people are useing them. I understand the trim needs to be removed on the passenger side A pillar to fit it. Will this trigger the airbag? Do I need to remove the paint before sticking to the body? (the kit came with no instructions at all)
If the aerial isn't suitable, what kind of aerial do I need, or woudl it be feasable to mount it in the rear quarterlight window instead?
#2 Mark M
Mark M
    TF regular
  • 1341 posts
  • Vehicle Driven:Mk4 Mondeo 2.5t
  • Name:Mark
Posted 02 March 2021 - 08:21 PM
If you have a look at - https://talkford.com...-or-double-din/
Near the bottom is a picture of where I fitted my DAB antenna and it's been working just fine for me.
There isn't an airbag in the A pillar trim to worry about, pull off the weather seal from around the door (just where the A pillar trim is will do) then just pull the plastic trim towards the drivers seat carefully at the top first. You will see a plastic yellow strap that is holding the trim to the body, just unclip it and pull the trim up from the dashboard.
In my case I didn't need to remove any paint, the magnet stuck to the pillar and that apparently is enough for it to work.
RamAir Pod Filter   -   Elevate FST225 Top Pipe   -   Airtec FMIC   -   Scorpion Downpipe   -    Scorpion Cat Back Exhaust   -   ECV Valve   -   RS DMF + Clutch Kit   -   Bluefin Stage 2
Sports Rear Diffuser   -   Sports Top Front Grill   -   Sports Bottom Front Grill   -   Sports Fog Lights   -   Sport Pedal Covers   -   Dark Ice Designs Auto Lift Boot Struts   -   Dark Ice Designs Bonnet Rams   -   Dark Ice Designs Short Shift Kit   -   Auto Mirror Mod   -   Interior LED Conversion   -   Nextbase 402 and 512 Dashcams  -  Convers Mod
295bhp & 450nm of fun, but can still give 38mpg  :driving:
