Hand Brake light permanently on Mondeo MK3 - Electrical (Mk3 Mondeo) - TalkFord.com
6 replies to this topic
#1 FredPenny
FredPenny
  • 4 posts
  • Vehicle Driven:Mondeo MK3
  • Name:Eoghan Reynolds
Posted 20 February 2021 - 04:06 PM
Hello all,
This has me stumped.
Hand-brake warning light on all the time. Was intermittent at first.
New pads, discs, hubs and ABS sensor. Pads are not the wearing-thin-to-connector-wire type.
ABS light not on.
New hand brake switch (5v from switch to chassis).
12v at float switch connector plug to reservoir.
Replaced reservoir anyway in case it was a dodgy float switch.
No leaks, reservoir holding steady at full.
Brake light bulbs working.
Think master cylinder is ok as pedal firm when car is off and gives a little when turned on.
No fault codes for what that's worth.
Can't find a wiring diagram anywhere.
Brake pedal has more travel than I'd like but I guess I need to bleed the system.....next job. That'd hardly affect hand-brake warning light though.
Thanks in advance.
Edited by FredPenny, 20 February 2021 - 04:12 PM.
#2 Grumpyaxeswinger
Grumpyaxeswinger
  • 480 posts
  • Vehicle Driven:Mondeo titanium X
  • Name:Hamish Craig
Posted 20 February 2021 - 04:22 PM
Had something similar on my first car a MK1 fiesta. I can't remember the exact details but it was to do with brake fluid leaking into the servo. I'm afraid j can't remember how the traced it but the brake servo was changed and the problem was sorted.
Sent from my J8210 using Tapatalk
#3 FredPenny
FredPenny
  • 4 posts
Posted 20 February 2021 - 05:32 PM
Thanks for that. Have a spare master cylinder, may switch that out in case there is a servo leak. Hope it's not a module or dashboard thing 😓.
#4 nicam49
nicam49
  • Gold Member
  • 4279 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Nick
Posted 20 February 2021 - 08:40 PM
There's a wiring diagram in the Haynes manual...
#5 FredPenny
FredPenny
  • 4 posts
Posted 20 February 2021 - 10:23 PM
Must've missed that. I have the Mondy 03-07 Haynes Manual. What diagram No.?
#6 nicam49
nicam49
  • Gold Member
  • 4279 posts
  • Name:Nick
Posted 23 February 2021 - 02:04 PM
It's in the green one, I think I can pm you with a pic of the page.
#7 FredPenny
FredPenny
  • 4 posts
Posted 25 February 2021 - 03:35 PM
Ah, I've got the red one.
In any case looked at the wiring diagram you sent, BK/RD cable seems to go directly to cluster. Removed that (very straightforward) popped in another cluster and bingo light goes off!!!!! Mileage much higher now. I read somewhere that the cluster stores the mileage and not the ECU. Anyway, it's working. Thanks for your help Nicam, saved me a painful "computer says no" trip to the dealer.
3 user(s) are reading this topic
    Bing (1)
