Fusion driver's door won't stay closed - Ford Fiesta Mk6 & Fusion (UK Model) Forum - (2002-2008) - TalkFord.com
fusion door lock drivers door worn latch
4 replies to this topic
#1 briangberry8
briangberry8
  • 2 posts
  • Vehicle Driven:Fusion
  • Name:Brian Berry
Posted 07 February 2021 - 10:39 AM
Hi,
07 Fusion, just the other day noticed the door won't close properly and stay closed. On closer inspection, I can operate the latch manually but there is no real spring compared to the passenger door (much less usage in its life?) and the door will not stay closed. The door will just about sit half-closed but I can pull it open easily.
I'm guessing I need a new driver's door lock mechanism due to wear? £232 quote from local Ford garage, yes that's right.
Am I missing something simple I could be doing to fix this?
Are the door locks with any other doors (Fusion) or any other Fords (Fiesta etc..) interchangeable, to make it easier to source via scrappy etc.. - or must if be a driver's door unit from a Fusion?
TIA
Brian
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29167 posts
Posted 08 February 2021 - 08:28 PM
Broken spring or not lubricated properly?
Fusion is essentially a Fiesta.
  • briangberry8 likes this
#3 briangberry8
briangberry8
  • 2 posts
  • Name:Brian Berry
Posted 10 February 2021 - 10:26 AM
Lubrication fine. Unsure if it's a broken spring or some other wear/break, I suspect wear as the door retention half (1/4) works.
Can anyone confirm this is the same part as a Fiesta - I can source a Fiesta driver door lock mechanism ok, but specifically the Fusion seems very rare. If they are the same, then great.
TIA
Brian
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29167 posts
Posted 10 February 2021 - 06:00 PM
Fusion locks on ebay for £15 ish.  Plus several breakers who maybe worth contacting
for prices.
#5 mondy zetecs
mondy zetecs
    Clever Clauggs
  • 4208 posts
  • Name:Harry
Posted 10 February 2021 - 07:27 PM
http://www.catcar.in...DIwMDEtMjAxMiJ9
http://www.catcar.in...TQxNzkzMjgrMTM3
For peace of mind compare the lock parts in above sites.
Edited by mondy zetecs, 10 February 2021 - 07:32 PM.
Fiesta 1.0 ecoboost 2014
Also tagged with one or more of these keywords: fusion, door lock, drivers door, worn latch
