Hi all, I own a 2010 X Sport with 59k on the clock. Last year the eml started flashing, then loads of white smoke and misfiring. Managed to get home just.
Plugged it in and came up misfire in cylinder 3. So I ordered 4 coil packs from Ford and changed them all.
Everything was fine till last week when the same thing happened. So I unplugged them one by one and came up misfire in cylinder 3.
Right. Reset the eml and code. Started the car again and it said multiple random misfire.
I ordered 4 connectors for the coil packs and rewired them. It's still the same. Now I'm thinking injectors.
Any help would be appreciated.
Number 3 plug is wet with petrol and the other 3 are sooty.
I've changed all the plugs and makes no difference.
I've also noticed when I press the start button but without starting the engine there's a clicking sound coming from under the passenger dashboard. It only lasts a few seconds then stops. Don't think it was there before but not sure really.
Ideas anyone..
Ideas anyone..
