Mart1001 has posted in Whining noise when at full temp and other issues - 2010 mondeo 2.0tdci in Diesel Engines (Mk4 Mondeo).
Yesterday, 11:28 PM
Colum has started Drivers door mirror complete failure in Ford Fiesta Mk7 Forum - (2008-2017).
Yesterday, 07:55 PM
bobalong has posted in Whining noise when at full temp and other issues - 2010 mondeo 2.0tdci in Diesel Engines (Mk4 Mondeo).
Yesterday, 07:54 PM
abithefox has posted in Ford KA 2010 Clutch? squeak after long run in Mechanical (Ka Mk2).
Yesterday, 05:31 PM
daktona has posted in MK4.5 2.0 tdci frequent DPF regens in Diesel Engines (Mk4 Mondeo).
Yesterday, 04:56 PM
PURPLE_2L_LX has posted in Reset air bag crash data and fault code :) in Ford Fiesta Mk7 Forum - (2008-2017).
Yesterday, 04:26 PM
Milk Cat has posted in Front anti-roll bar removal in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Yesterday, 03:51 PM
Acceleration and engine braking
Started by
Mrfrench02
, Jan 24 2021 08:15 PM
2 replies to this topic
#1
Posted 24 January 2021 - 08:15 PM
Hi guys, new to the forum and have a query pls.
2011 fiesta 1.5 diesel with 100k on the clock. I seem to have a momentary lapse of power at every gear change. As soon as i make the change, lift the clutch and try to accelerate i have about 2 second delay before i have power again. Also when driving generally in gear and come off the gas, i feel usual engine braking for a second or two but then i feel an increase in slowing as if the brakes are sticking. I can't help but think the accelerating and engine braking are connected? Any ideas? Is the accelerator electric rather than cable controlled?
#2
Posted 25 January 2021 - 05:04 AM
Lapse of power as in the turbo is not boosting or the revs are increasing but
not the speed (slipping clutch)?
What revs are you going from and to when changing up?
#3
Posted 25 January 2021 - 06:55 PM
I dont think it's the clutch slipping, feels like sluggish as if u change gear too early and ur going uphill, it takes a couple of seconds to build up speed and catch up before taking off again. Perhaps the turbo?
But that wouldnt contribute to the engine braking would it? Maybe two different issues? Is there a way to test if turbo is working properly?
Revs are being changed between 2000-2500, resting at about 1750 for the next gear
