Steve1M has started Reverse gear issue...clutch bleed question in Drivetrain (Mk4 Mondeo).
Today, 01:27 PM
Albacore has posted in Stop/Start- Clutch Master Cylinder Problem in Electrical (Focus Mk3).
Today, 11:49 AM
Vanadeo has posted in Recon rack problem. in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Today, 06:56 AM
how do i remove this broken thing?
Started by
dojj
, Jan 21 2021 09:32 PM
11 replies to this topic
#11
Posted 28 January 2021 - 09:06 PM
Yup, what a pain in the RS it is to remove that plastic!!!
And it took the best part of an hour to file down the shaft so that the new gear would fit over the top
Now my predicament is that the hole in the cog in 2.5mm
The drill bit supplied is 3mm
The roll pin in 3.5mm
What do I do other than bust out the pillar drill
mk3 mondeo ghia x estate 2.0 auto with:
362mm 6 pot ap stoppers lurking behind some 8 x 18 comps
tv fitted to facelifted dash + headrest screens for both kids
full st kit + powerfolds w/puddlelights with jp stainless exhaust
shonky n/s/f rattle fixed by totd whoopie!
most of the chrome bits done
#12
Posted 29 January 2021 - 08:34 PM
this is what the plastic cog is moulded onto so yeah, it's not going to come off in a hurry lol
eventually i drilled out a 2.5mm hole all the way through
then i followed through with a 3mm drill bit
then i opened it up to 3.2mm all the way through
finally, because the roll pin wasn't going through, i stuck a 3.5mm hole in one side of the cog and just a little bit into the shaft to get things started, knowing that when it hit the 3.2mm hole it would get stuck and then hammered it home
