Brompton has posted in 2.0Tdci Oil Specs And Standards in Diesel Engines (Mk4 Mondeo).
Today, 01:17 PM
dojj has posted in where to get one of these oily rubbery things from then? in Interior / Exterior (Mk3 Mondeo).
Today, 10:37 AM
riber3 has posted in Ford Granada Mk2 Estate Boot Size/Capacity in Ford Granada Forums & Ford Scorpio Forums.
Today, 10:11 AM
Krokogator has posted in MMT6 Gearbox loose 1st and 2nd gear in Transmission / Drivetrain (Mondeo Mk3).
Today, 09:12 AM
tailgate doesn't open with switches but the remote works
Started by
ul9601
, Jan 20 2021 02:50 AM
10 replies to this topic
#1
Posted 20 January 2021 - 02:50 AM
I expected all three opening methods (interior s/w, tailgate mounted s/w & remote s/w) would use the one and the same wiring but obviously this is not the case?
E.g. Battery +12V -> switches (in parallel) -> solenoid -> ground.
In case of remote s/w, +12V -> remote receiver -> solenoid-> ground.
Am I missing something?
2003 Mondeo 2.0 Duratec HE petrol MTX-75 5 speed manual (pre-face Mk3)
#2
Posted 20 January 2021 - 06:21 AM
On my hatchback the interior switch on the console worked after changing
drivers door lock module.
Fiesta 1.0 ecoboost 2014
#3
Posted 20 January 2021 - 06:52 AM
The switch in the handle and the interior switch are on the same connection.
If one switch is activated or a wiring fault then neither switch will work.
As above also the drivers door lock can cause boot opening issues.
#4
Posted 21 January 2021 - 02:16 AM
I've been pulling apart the tailgate - the tailgate switch seems buggered. what happens is with the switch disconnected, dash switch works. when reconnecting the tailgate s/w, it operates the solenoid but that's it, it doesn't work any more.
I was going to disconnect the tailgate lock and install a private lock but there are no holes pre-punched. I was of understanding all pre-facelift had the holes, regardless whether a private lock has been fitted to a particular car. I guess I was wrong again.
#5
Posted 21 January 2021 - 08:24 AM
well, thank god for the time difference so i managed to sort of figure it out before you guys could...
it appears that the rubber membrane for the tailgate switch somehow jammed it "on", which explains the solenoid working when disconnected and then re-connected. there must be a protection circuit or something so that continuous press doesn't register.
i don't know how the membrane jammed it in though, it was still flexible and wasn't caught on anything...
- mondy zetecs likes this
#6
Posted 21 January 2021 - 09:07 AM
looking back, i made a few rambling posts of tailgate switches and private lock...
raykar posted a photo of a cutout he had to make to retrofit a lock back then so thanks!
#7
Posted 22 January 2021 - 10:54 PM
If you're interested, somewhere on this site is/was an account of how to replace the switch in the tailgate with a microswitch from an old pc mouse.
- ul9601 likes this
#8
Posted 22 January 2021 - 11:27 PM
A spare mouse is something I'm always short of. But I think I have a couple of micro switches in my stash somewhere.
I'll search the forum.
#9
Posted 23 January 2021 - 11:42 AM
Found this one.... (not quite the one I had in mind, but...)A spare mouse is something I'm always short of. But I think I have a couple of micro switches in my stash somewhere.If you're interested, somewhere on this site is/was an account of how to replace the switch in the tailgate with a microswitch from an old pc mouse.
https://talkford.com...=1#entry1090579
- ul9601 likes this
#10
Posted 23 January 2021 - 07:38 PM
yes I found that one - thanks
