bolts? which ones? where from? - Mondeo Mk3 General Discussion - TalkFord.com
6 replies to this topic
#1 dojj
dojj
    Resident Wrestling Legend
  • 3927 posts
Posted 16 January 2021 - 06:12 PM
today i went back into the garage for the second time since getting the rona and i've got my seat in bits on the floor
REALLY long story short, it's on youtube if you want to see
i've removed the seat motors and runners from my 2 way electrical adjustable seat to swap over to my 8 way adjustable (it's complicated but i'm going to use the 2 way height adjustment as the front/rear frame fouls the dvd player and it won't fit) but now that i've removed the 8 metal rivets that hold the motors in place i need to find some suitable bolts to replace them with
i know how big the holes are i need them to go through, but they need to fit fairly snuggly, so do bolts that i need exist?
i need the shoulder to be maybe 8mm deep max but google doesn't help me so far as i don't know what to ask for, i can give head sizes and lengths and stuff but they also need to be rated to hold seats in place rather than just buying some bolts that won't be up to the job
thanks
mk3 mondeo ghia x estate 2.0 auto with:
362mm 6 pot ap stoppers lurking behind some 8 x 18 comps
tv fitted to facelifted dash + headrest screens for both kids
full st kit + powerfolds w/puddlelights with jp stainless exhaust
shonky n/s/f rattle fixed by totd whoopie!
most of the chrome bits done
#2 Flynn50
Flynn50
    Advanced Member
  • 43 posts
  • Vehicle Driven:Mondeo Mk3 130 TDCi
  • Name:Andy Bell
Posted 16 January 2021 - 06:56 PM
A standard DIN 931 bolt has a thread length of 2d + 6mm. So an M8 x 30 bolt will have a shoulder 8mm long and 22mm of thread.
DIN 931 is a hexagon head though, not Allen key drive. If 22mm of thread is too much you could always cut it down but need to ensure you can still get a nut on afterwards.
Sent from my SM-G960F using Tapatalk
#3 Flynn50
Flynn50
    Advanced Member
  • 43 posts
  • Name:Andy Bell
Posted 16 January 2021 - 07:06 PM
If you get an 8.8 high tensile zinc plated bolt you should be fine.
#4 raynkar
raynkar
    Dash cams, catch 'em out :)
  • 12828 posts
Posted 16 January 2021 - 08:50 PM
I might be missing something obvious, but why can’t you just use rivets to replace the rivets you removed?
#5 dojj
dojj
  • 3927 posts
Posted 21 January 2021 - 01:11 AM
Because they are those rivets that are the squashed together by a big machine with the force of 500 tons type rivets :(
  • raynkar likes this
#6 dojj
dojj
  • 3927 posts
Posted 22 January 2021 - 07:06 PM
what i need are the same bolts that are used to hold the seat adjuster motors in place, but i can only find 3 per 8 way seat (or 1 per 2 way) so it's going to be a bit of an effort unless i can get the part numbers for these bolts and order them?
#7 dojj
dojj
  • 3927 posts
Posted 22 January 2021 - 07:18 PM
they go into these holes
7zap seems to indicate that they aren't sold separately so arse :(
141793297_3287003338071637_8473308146697
