Albacore has posted in Stop/Start- Clutch Master Cylinder Problem in Electrical (Focus Mk3).
Today, 11:49 AM
Vanadeo has posted in Recon rack problem. in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Today, 06:56 AM
steffenbk has started Good front Anti Roll Bar Link / Sway Bar Link to buy? in Mondeo Mk4 General Discussion.
Today, 06:19 AM
EML P00BD:64-AF on every drive 2.0tdci Galaxy mk3
Started by
steviec2000
, Jan 14 2021 10:10 PM
1 reply to this topic
#1
Posted 14 January 2021 - 10:10 PM
Hi, I've got a Ford Galaxy 2011 mk 3with the 2.0l 163bhp tdci engine. Which I need some help with.
For the past 3 weeks on every trip I get an engine warning light a good 5 to 10 minutes or so after driving. This then puts the car into limp mode. To me it appears to fault after driving for a 5-10 minute period, usually when I am doing 50/60 mph on the dual carriageway.
I've checked the code and it's a P00BD:64-AF. Which when I look is a high reading from the MAF sensor.
I've since cleaned the sensor very carefully with the MAF cleaner and replaced, but still the error appears after each drive.
I've checked for vaccum leaks bit can't see any (any tips on any specific places to check are appriciated). I've took some measurements but am unsure if they provide any clue to that actual problem? Can anyone help? I'm unsure if it's a MAF, IAT, air charge sensor fault, or indeed something else?
Cold engine
Ambient air - 5 degrees Centigrade
Air charge temp - 6 degrees Centigrade
Intake air temp - 8 degrees Centigrade
MAF - 1.87 g/s
Warm engine after 15 mins of ideling (stationary)
Air charge temp - 17 degrees Centigrade
Intake air temp - 13 degrees Centigrade
MAF - 16 g/s
Warm engine driving at 40mph (warning light came on during this drive)
Ambient air - 2 degrees Centigrade
Air charge temp - 14 degrees Centigrade
Intake air temp - 4 degrees Centigrade
MAF - 89.83 g/s
Thank you for any advise you can give.
Cold engine
MAF - 1.87 g/s
MAF - 16 g/s
MAF - 89.83 g/s
#2
Posted 15 January 2021 - 05:54 PM
89.83 is rather high, try comparing the throttle position reading to the MAF reading
do they increase linearly or does the MAF spike?
