Electrical problems - Ford Fiesta Mk7 Forum - (2008-2017) - TalkFord.com
Electrical problems
fiesta electrical indicators auto electrician
8 replies to this topic
#1 Hallstar
Hallstar
  • 5 posts
  • Vehicle Driven:fiesta
  • Name:Andrew Hall
Posted 14 January 2021 - 06:01 PM
Few problems on my 2009 Ford fiesta Zetec s 1.6 diesel
Indicators not working, noise of clicking in car at approx twice speed
Hazards not working
brake lights work when no lights on, when lights on (which appear to be as bright as the brake lights) no change in brightness when pedal pressed.
Car has been stood during 2020 and battery went flat, jump started the car which i have been informed is not recommended.
Have fitted new battery now.
have checked fuses and all look good.
If not an easy fix, can anyone recommend a auto electrician close to Portsmouth/Southampton  ?
Thanks for your help
Edited by Hallstar, 14 January 2021 - 06:07 PM.
#2 Hallstar
Hallstar
  • 5 posts
  • Name:Andrew Hall
Posted 25 January 2021 - 03:41 PM
ok
Anyone recommend an auto electrician close to portsmouth/southampton then ?
#3 Mondygeek
Mondygeek
    dont listen to me, you'll have horsepower and no money
  • 3170 posts
  • Name:Ben
Posted 25 January 2021 - 04:26 PM
ok
Unfortunately can't recommend an auto electrician but I'm pretty confident you body control module (bcm) is faulty. It lives behind the glovebox, if you can try and get a picture of the part number on it and post it because I have a spare bcm then you can program yourself using forscan
#4 Hallstar
Hallstar
  • 5 posts
  • Name:Andrew Hall
Posted 26 January 2021 - 02:48 PM
Thanks for your reply
here is a picture of the BCM
not sure which is the important coding on the label
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28993 posts
Posted 28 January 2021 - 07:40 PM
8V51-15K600-EG
Flasher at twice the speed if often when a bulb is out. Any water leaks in the car?
#6 Mondygeek
Mondygeek
  • 3170 posts
  • Name:Ben
Posted 28 January 2021 - 09:59 PM
8V51-15K600-EG
Hazards would work regardless
#7 Mondygeek
Mondygeek
  • 3170 posts
  • Name:Ben
Posted 28 January 2021 - 10:30 PM
My bcm part number is a direct match!
  • Hallstar likes this
#8 Hallstar
Hallstar
  • 5 posts
  • Name:Andrew Hall
Posted 29 January 2021 - 03:24 PM
8V51-15K600-EG
had a leak in boot from rear light unit as somehow the grommet mounts had disappeared (don't know how as had car from new) but dried out and ok now
#9 Hallstar
Hallstar
  • 5 posts
  • Name:Andrew Hall
Posted 24 February 2021 - 07:53 PM
Bit the bullet and took it to a local auto electrician
found a bad earth going to the rear light unit
All sorted now, thanks for all the reply's
now for the MOT
Also tagged with one or more of these keywords: fiesta, electrical, indicators, auto electrician
