Posted 06 December 2020 - 06:28 PM
Hi
Do you still have the old brake pads if cable is complete on one, you can plug into chassis connector on each side to check if one of the new pad circuits is faulty. Assuming warning light has only come on after work something has been disturbed, it may take a take a check for electrical continuity to find problem.
Another item to check does warning light illuminate if hand brake is partially on, is rear break adjusted correctly allowing lever to drop fully to floor.
Leak in pipe will only cause problem if system dropped level but obviously needs fixing as soon as.
Peter
Previously Mondeo MK2 ST200.
Previously Sierra XR4x4.
Previously Escort XR3i, Capri, Sierra, Escorts RS2000, RS1600, Mexico & 1300GT..
