Ford KA 2010 30,000 miles only , Clutch? pedal? makes squeak after long run
The clutch has started making a loud squeaky sound when you press and lift off the pedal. This only seems to start after the car has been running for a good time with a lot of gear changes and continues when the engine is turned off but once its been left for a while it stops. So when you drive the next day the sound has gone
typical i have booked it in the the garage and sent them videos but they have refused to change any parts (under warranty) and cant find the noise or where it coming from Because its always ok for them.
2 x videos of noise
