Oil Sump Leak - Which is the correct Gasket - V6 'Duratec' Petrol Engines (Mondeo Mk3) - TalkFord.com
4 replies to this topic
#1 Soupasun
Soupasun
  • 4 posts
  • Vehicle Driven:Mondeo Zetec S 2.5
  • Name:Sunil Singh
Posted 01 December 2020 - 10:45 AM
Hoping someone can help. I have an 03 plate 2.5 v6 Mk3 that has oil around the sump. I have been advised by a mechanic that he is unsure of the gasket used and an online search brings up 2 types, a metal framed one and a rubber gasket one. Does anyone know which is the correct part? Thanks in advance.
#2 mondy zetecs
mondy zetecs
    Clever Clauggs
  • 4208 posts
  • Name:Harry
Posted 01 December 2020 - 10:53 AM
http://www.catcar.in...TQ1NDcyKzMxMg==
https://www.ebay.co....763355&_sacat=0
The ford gasket is expensive £74,
Can use aftermarket gasket and or oil sump gasket paste with it.
Edited by mondy zetecs, 01 December 2020 - 10:58 AM.
Fiesta 1.0 ecoboost 2014
#3 Soupasun
Soupasun
  • 4 posts
  • Name:Sunil Singh
Posted 01 December 2020 - 07:53 PM
Thanks.
#4 raynkar
raynkar
    Dash cams, catch 'em out :)
  • 12919 posts
Posted 01 December 2020 - 10:50 PM
As per above, as your car is an 03 it’s most likely to have the metal type gasket shown above.
In the event your car was made after November 03 it could have the rubber type.
It’s pretty much the case that the 5 speeds have the metal type and 6 speeds have the rubber type.
Here is a vid that shows both types.
https://youtu.be/tESwVIFYTGs
Edited by raynkar, 01 December 2020 - 10:55 PM.
#5 raynkar
raynkar
  • 12919 posts
Posted 01 December 2020 - 10:58 PM
For info, this is a later type sump from a 6 speed car, you can see the groove in the sump where the later rubber type gasket sits.
