raynkar has posted in bolts? which ones? where from? in Mondeo Mk3 General Discussion .
Today, 08:50 PM
Flynn50 has posted in bolts? which ones? where from? in Mondeo Mk3 General Discussion .
Today, 07:06 PM
Disconnect Leak Off Pipe From Fuel Pump
Started by
Dean131066
, Nov 24 2020 04:49 PM
6 replies to this topic
#1
Posted 24 November 2020 - 04:49 PM
Can anyone explain how to release the clip that attaches the leak off return pipe to the fuel pump? I've attached a photo showing the elbow circled in red. I was expecting this to unclip in the same manner that the fuel lines attach to the fuel filter with a clip that slides sideways, however, no amount of force seems to be working so I'm wondering if there's something different about this clip. Thanks.
#2
Posted 24 November 2020 - 09:09 PM
AFAIK, it doesn't. It's part of the venturi assembly which is removable as a unit. Tomorrow I'll check on a spare I've got and let you know, unless someone beats me to it.
#3
Posted 25 November 2020 - 09:49 AM
I'm looking to pull the leak off pipe out of this elbow. I appreciate that the elbow is well attached to the pump assembly. Thanks
#4
Posted 25 November 2020 - 08:54 PM
Just push the white bit of plastic in and give the other end a good yank
- nicam49 likes this
#5
Posted 25 November 2020 - 10:52 PM
Enlightenment! I'd read the original query wrong.
Yes, as above. Press the white tab in and pull
#6
Posted 27 November 2020 - 06:22 PM
I've been trying to pull the white tab UP so this may explain my lack of success! Many thanks for your replies and hopefully the mystery is now solved.
#7
Posted 27 November 2020 - 08:12 PM
Not a problem that’s what this forum is here for!
