Slider pin with rubber sleeve in the bottom hole,
have read the holes on the carrier are marked appropriately or holes are slightly
different size,though i've managed to get the sleeve in both.
Edited by mondy zetecs, 23 November 2020 - 07:27 AM.
Today, 04:52 PM
Today, 03:36 PM
Today, 03:26 PM
Today, 03:01 PM
Today, 01:36 PM
Today, 12:52 PM
Today, 10:46 AM
Today, 10:26 AM
Today, 10:11 AM
Posted 23 November 2020 - 07:21 AM
Fiesta 1.0 ecoboost 2014
Posted 23 November 2020 - 07:42 AM
Cheers mate,,Slider pin with rubber sleeve in the bottom hole,
Posted 23 November 2020 - 07:56 AM
Haynes says locate the rubber bush on the lower guide pin
Larger hole for rubber sleeve slider pin.
Edited by mondy zetecs, 23 November 2020 - 08:12 AM.
Posted 23 November 2020 - 08:09 AM
Posted 23 November 2020 - 01:41 PM
Hi
Clean away the crap where the pins fit into carrier, you should find a dimple drilled into machined face beside one hole. This should be the hole where pin with damper bush fits.
This was definitely on the later MK3 brakes with square pads, hope it’s also there on your earlier carriers with the curved ended pads.
Peter
Edited by ST56, 23 November 2020 - 01:43 PM.
Posted 23 November 2020 - 07:54 PM
Posted 24 November 2020 - 09:38 AM
Posted 24 November 2020 - 08:12 PM
Posted 25 November 2020 - 12:37 PM
Hi
This pic I posted on this previous topic: https://talkford.com...er#entry2610881
Has I mentioned in previous post, this indentation was found on the later carriers with the square ended pads. Looks as if not included on earlier design.
Peter
Posted 25 November 2020 - 12:51 PM
