Power steering leak - Suspension / Wheels / Brakes / Steering (Mk3 Mondeo) - TalkFord.com
Power steering leak
4 replies to this topic
#1 Russpuppy72
Russpuppy72
  • 2 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Russ
Posted 19 November 2020 - 06:42 PM
Hi new here is it possible to change just the o rings on the pressure pipe From the power steering pump or is it a new pipe and connection part which screws in the pump too. As I've read there's a diagram Spring so should be cay. I have a leak and can't tell if the pipe or the union connection. Thanks
#2 nicam49
nicam49
  • Gold Member
  • 4197 posts
  • Name:Nick
Posted 19 November 2020 - 07:15 PM
I bought new O rings when my old pump seized up, but couldn't seperate the nuts. Ended up just unscrewing the pipe at the pump. Still got the new O rings.... somewhere...
#3 Russpuppy72
Russpuppy72
  • 2 posts
  • Name:Russ
Posted 22 November 2020 - 07:53 AM
Ok thanks did that solve your leak. As if its the pipe end it might be a stealer job.
#4 nicam49
nicam49
  • Gold Member
  • 4197 posts
  • Name:Nick
Posted 22 November 2020 - 05:16 PM
Hi, have a read of this thread, to get some idea of what to do.
https://talkford.com...-failure/page-1
#5 nicam49
nicam49
  • Gold Member
  • 4197 posts
  • Name:Nick
Posted 26 November 2020 - 09:34 PM
Bit of a late reply here, but undo the big nut and there's an 0 ring you can change.
