Mondeo Mk3 Turbo issues - Page 3 - Diesel Engines (Mondeo Mk3) - TalkFord.com
21 replies to this topic
#21 Jonnyboy07
Jonnyboy07
  • 11 posts
  • Vehicle Driven:Mondeo TDCI
  • Name:Jonathan Wildman
Posted 26 November 2020 - 10:32 AM
Hi all,
It appears it was the MAP sensor after all.
Ordered another MAP sensor, fitted it and the computer didn't turn the turbo off when the engine fired up.  The code P0235 also cleared this time whereas last time it wouldn't clear (obviously because the problem still existed).
For anyone else having the same issues, to clear codes P0105 - (Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction) and P179A - ( Boost pressure control device malfunction) I took the MAF sensor off and cleaned that, changed the air filter, changed the turbo actuator (exact part number matches), took the EGR valve off and cleaned all the soot and dirt out from that an checked all hoses for splits.
To clear code P0235 - (Turbo/Super Charger boost sensor A circuit) I bought another MAP sensor (exact part number matches).
Also bought an OBD2 scanner (with CAN-BUS  connection) to read and clear codes myself; bought off Amazon for £18.99 where garage charged £60 to originally read codes - no brainer to buy one.
Obviously the low grumble noise I got at the beginning was the result of the computer turning the turbo turning off (to protect it) and it being wide open.
Cheers to one and all for all your input and knowledge
Cheers to DavieWeegie....you were right it was the MAP sensor.
  • DavieWeegie likes this
#22 DavieWeegie
DavieWeegie
    Mondeo Lover
  • 680 posts
  • Vehicle Driven:Mondeo ST TDCI 2005
  • Name:David
Posted 26 November 2020 - 01:25 PM
glad you got it sorted
  • Jonnyboy07 likes this
Performance Blue Mondeo ST TDCI 2005
