raynkar has posted in What did you do with your Mondeo today in Mondeo Mk3 General Discussion .
Today, 04:24 PM
getsome has posted in MK4.5 2.0 tdci frequent DPF regens in Diesel Engines (Mk4 Mondeo).
Today, 12:30 PM
riikomi has posted in 2.2 tit x sport glow plug change in Diesel Engines (Mk4 Mondeo).
Today, 11:46 AM
Mondeo 2.0 TDCi 2012 - DPF pressure differential readings
Started by
Steve1M
, Oct 30 2020 08:17 PM
27 replies to this topic
#21
Posted 12 December 2020 - 12:52 PM
#22
Posted 17 December 2020 - 07:39 PM
Thanks for video link.
Received my 22mm crows foot spanner....will do after Xmas when have time.
Quick check just now, following 2 x 40 minute drives....mix 70/50mph + urban....soot dropped to 41%!!
I'm going to swap it out anyway.
Merry Xmas all, and tks again for all your help.
#23
Posted 23 February 2021 - 03:40 PM
Success!!
Soaked it in penetrating fluid.
Breaker bar shifted it easily...bit of a non-event really.
Vapouriser hole really sooted up...only letting tiniest amount of air through. (diesel doesn't taste nice!!)
Glow was 1.1ohms,so good.
Applied dab Mintex Ceratec on re-assembly.
Probably won't bother force regen..just let it do its thing.
What a relief, as was all prepared with blow torch/extinguisher/garden hose and candle wax....latter in case penetrating fluid didn't work.
(you may think fire extinguisher a bit OTT, but changed track rod end on wife's car last summer.Lots of penetrating fluid on thread, mopped up lots of excess with blue roll.Lock nut needed some heat, you know the rest...nice inferno under engine!!!)
Hopefully anyone reading this will be as lucky as me.
Again, really grateful for all of your invaluable information/advice.
Rgds, Steve.
Rgds, Steve.
#25
Posted 23 February 2021 - 04:41 PM
Good stuff
That looks worse than the one that came out of my car, but mine was blocked solid, couldn't blow through it at all.
Mondeo 2.2 TDCI Titanium X Sport (MK4.5), Panther Black | S-Max 2.5T front brake calipers and 316mm discs | Fuel Log
Now Dead - Mondeo ST24, 2000 W reg, Amparo Blue | ST170 Calipers and Discs | Goodridge Hoses | GW Decat | K&N Panel Filter | Black eyes | LPG
Honda Hornet, 2004, Matt Blue.
#26
Posted 24 February 2021 - 04:16 PM
That’s good news Steve....My 2.2 gets mainly short town runs (especially since lockdown)....I have been using “wynns total system” treatment roughly twice a year & don’t want to scud myself but so far “fingers crossed “....Our lockdown will continue to Easter(That I’m assured) & possibly further....With mot in April I will just have to Hope & Pray As You cannot travel further than 10 miles from home...Heavy fines imposed for breaking....They are really strict here but I suppose it’s best safe than Sorry...As a footnote...Anybody relatively healthy getting 1st Astra Zeneca....Have a back up plan/time off work booked as it WILL knock your pan out for few days...Best Regardspic
#27
Posted 24 February 2021 - 07:41 PM
Just did static regen, as wanted peace of mind that pump was primed OK.
Sat at 2800 for approx 25 mins, and end result was:-
"(OK) [17:44:10.100] Regeneration started. Please wait...25 min
(OK) [17:44:13.144] Static regeneration is in the warm up phase
(OK) [17:46:09.453] The diesel particulate filter is in the regeneration phase
(OK) [18:21:11.279] Static regeneration is in the cool-down phase
(ERR) [18:22:30.106] Regeneration time exceeded allowable limit
(ERR) [18:22:30.107] Perform a self-test to identify whether DTC P2463 is still present
(ERR) [18:22:30.108] If DTC P2463 can be cleared the regeneration has been successful"
Did a re-scan for DTCs, and P2463 was NOT present, so presume all is basically OK (??)
Checked levels:-
DPF_SOOT_LOAD 9%
DPF_LOAD 35%
DP_DPF 2kPa, at 2100rpm
It's a shame it is not possible in Forscan to view soot/temp/pressure in real time, during regen., to watch it doing its magic.
It just gives a summary log, as above. (maybe the paid version allows this...who knows?)
Steve
#28
Posted 25 February 2021 - 06:47 AM
Interesting, I have the same issue with mine.
Changed the vaporiser with a genuine one from Ford, did static regen and same error: Regeneration time exceeded allowable limit
During driving when it's doing regen the temperature gets only to 550-570C and as I heard it should be over 600
