Error Codes - Mondeo Mk3 General Discussion - TalkFord.com
Error Codes
9 replies to this topic
#1 Rekusu
Rekusu
  • 2042 posts
  • Vehicle Driven:Mk3 Mondeo, TDCI
Posted 30 October 2020 - 07:44 AM
What ho one and all,
Having reinstalled Formidable onto an old laptop, I was clicking around the various files and came upon a Formidable installed folder that contained a number of *txt files.  Out of interest, I opened them
One contains every (and I mean every) P error code known to mankind (although it does not have the recent thread relating to the P132B code!)
I think it has all the coded for cars that Formidable relates to, Mazda, Jag, etc included.  Seems to me, it could be useful somewhere on this forum.  Problem is, it runs to over 100 pages.  The following is a smaple:
P0100   Mass or Volume Air Flow A Circuit
P0101   Mass or Volume Air Flow A Circuit Range/Performance
P0102   Mass or Volume Air Flow A Circuit Low Input
P0103   Mass or Volume Air Flow A Circuit High Input
P0104   Mass or Volume Air Flow A Circuit Intermittent/Erratic
P0105   Manifold Absolute Pressure/BARO Circuit
P0106   Manifold Absolute Pressure/BARO Sensor Range/Performance
P0107   Manifold Absolute Pressure/BARO Sensor Low Input
P0108   Manifold Absolute Pressure/BARO Sensor High Input
P0109   Manifold Absolute Pressure/BARO Sensor Intermittent
P010A  Mass or Volume Air Flow B Circuit
P010B  Mass or Volume Air Flow B Circuit Range/Performance
P010C  Mass or Volume Air Flow B Circuit Low Input
P010D  Mass or Volume Air Flow B Circuit High Input
P010E  Mass or Volume Air Flow B Circuit Intermittent/Erratic
P010F   Mass or Volume Air Flow Sensor A/B Correlation
P0110   Intake Air Temperature Sensor 1 Circuit
Is it worth posting somewhere and if so, where?  And if so, can I upload a 100 page file?
Just checking the file and all the P codes are there, along with many B. C, and U.  May be these are the other cars?  If so, I can remove and the file come down to around 46 pages.
Toodle pip
Edited by Rekusu, 30 October 2020 - 07:46 AM.
What if the Hokey Cokey IS what it's all about?
#2 raynkar
raynkar
    Dash cams, catch 'em out :)
  • 12699 posts
Posted 31 October 2020 - 09:32 AM
There is a list of error codes in the Mondeo mk3 section of the Ford Wiki.
#3 raynkar
raynkar
  • 12699 posts
Posted 31 October 2020 - 09:36 AM
This is the Ford Wiki entry for comparison.
https://www.fordwiki...I_-_Fault_Codes
#4 raynkar
raynkar
  • 12699 posts
Posted 31 October 2020 - 09:39 AM
This is a link to the whole mk3 section just in case it’s of any use to anyone.
It contains over 200 guides or sets of info.
https://www.fordwiki...Sensor#mw-pages
#5 Rekusu
Rekusu
  • 2042 posts
Posted 31 October 2020 - 12:52 PM
I now a fairy; her name is Nuff - Fairy Nuff!
But this list only goes the P1899 and I had P2336.
I have found that  the fault codes are as follows:
  • P: Powertrain, (i.e. engine and gearbox)
  • C: Chassis
  • B: Body
  • U: User network
and the list from Formidable (104 pages worth) has them all.  OK, the vast majority do not apply to the old Mondies.  Additionally, it is easy enough to enter the error code in Google and see the result.
I just though it may be useful for the forum but have no idea how to post a 104 page document.
I did follow some of the links on the Delphi Common Rail Info link and they all lead to blank pages!
#6 raynkar
raynkar
  • 12699 posts
Posted 31 October 2020 - 04:13 PM
  • C: Chassis
  • B: Body
  • U: User network
Might be time for you to edit the entry, and add the extras :)
#7 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28695 posts
Posted 31 October 2020 - 06:32 PM
P2236  and P132A/B codes may show depending on the reader used.
OBD code list with the original F-Super.
Attached File  DTC2610EN.txt   317.34KB   11 downloads
#8 nicam49
nicam49
  • Gold Member
  • 4132 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Nick
Posted 31 October 2020 - 07:52 PM
Phew! That's a LOT of potential faults! Never had that trouble with the Ford Anglia
#9 Rekusu
Rekusu
  • 2042 posts
Posted 01 November 2020 - 12:36 PM
Purple,
That is pretty much the same file I was mentioning.
#10 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28695 posts
Posted 01 November 2020 - 03:23 PM
It should be its from the original F-Super (Formidable Software).
I was not sure the forum would allow the 317KB txt file.
