Fresh paint going cloudy - Car Care / Restoration / Paint - TalkFord.com
5 replies to this topic
#1 mondeoXT
mondeoXT
  • 111 posts
Posted 24 October 2020 - 08:45 PM
Can someone help me. Iv sprayed the lower front bumper skirt ready to be fitted to my car. Iv used panther black spray paint from halfords and their clear laquer. When its wet it shines like its supposed to but then dries cloudy like a matte finish with shiny parts in places. Iv wet sanded it with 1200 grit paper but no change. I can only spray in the garage as its constantly raining. Is it the fact im using spray cans or moisture in the air or does it just need a good polish to bring it back? I'm really stuck.
Sent from my SM-G975F using Tapatalk
#2 Mark M
Mark M
    TF regular
  • 1296 posts
  • Vehicle Driven:Mk4 Mondeo 2.5t
  • Name:Mark
Posted 24 October 2020 - 08:58 PM
If you've wet sanded it you may find compounding it will help but for your arms sake use a machine polisher, a good cutting pad and a good cutting compound.
RamAir Pod Filter   -   Elevate FST225 Top Pipe   -   Airtec FMIC   -   Scorpion Downpipe   -    Scorpion Cat Back Exhaust   -   ECV Valve   -   RS DMF + Clutch Kit   -   Bluefin Stage 2
Sports Rear Diffuser   -   Sports Top Front Grill   -   Sports Bottom Front Grill   -   Sports Fog Lights   -   Sport Pedal Covers   -   Dark Ice Designs Auto Lift Boot Struts   -   Dark Ice Designs Bonnet Rams   -   Dark Ice Designs Short Shift Kit   -   Auto Mirror Mod   -   Interior LED Conversion   -   Nextbase 402 and 512 Dashcams  -  Convers Mod
295bhp & 450nm of fun, but can still give 38mpg  :driving:
#3 DavieWeegie
DavieWeegie
    Mondeo Lover
  • 705 posts
  • Vehicle Driven:Mondeo ST TDCI 2005
  • Name:David
Posted 24 October 2020 - 08:59 PM
youll need to wet sand it will upto 3500 grit, the 1200 grit will still have quite a hazing from the small scratches it makes, you go progressively higher grit each time, so 1200-2000-2500-3500 and then the small scratches in the laquer can be cut and polished out a lot easier. for cutting compound use G3 or Meguires cutting compound, then use an actual polish to bring it right out.
Edited by DavieWeegie, 24 October 2020 - 09:01 PM.
Performance Blue Mondeo ST TDCI 2005
#4 mondeoXT
mondeoXT
  • 111 posts
Posted 24 October 2020 - 09:22 PM
Thanks guys iv never used a machine polisher, never sprayed anything till recently. Maybe I should go for a professional detailer after wet sanding again through the grit levels
#5 Magwheels
Magwheels
  • 6 posts
  • Vehicle Driven:Mondeo MK4
  • Name:Andy Conde
Posted 01 February 2021 - 04:59 PM
It needs a good polish. The trouble is that Halfords lacquer is like hairspray and has no build so you are likely to polish through it before you get a decent shine. I always use HB Body 496 as even though not 2k (as it gives the impression it is) it is a good high quality lacquer. It will take some time to cure in this weather though as it likes to be warm to cure properly. It does skin off quite quickly though so you will be able to move it to someplace warm without to much worry.
#6 ST56
ST56
    Clever cloggs
  • 2151 posts
Posted 01 February 2021 - 08:36 PM
Hi
Paint has probably bloomed over as temperatures a little low with moisture in the air. You can probably rescue it with a little vigorous polishing. If doing by hand just work on a small area at a time then finish by polishing the whole area.
Peter
Previously Mondeo MK2 ST200.
Previously Sierra XR4x4.
