Front Camber Issue - Suspension / Wheels / Brakes / Steering (Mk3 Mondeo) - TalkFord.com
Front Camber Issue
6 replies to this topic
#1 Tulejumal
Tulejumal
  • 57 posts
  • Vehicle Driven:Mondeo Mk3 2,0 Tddi
  • Name:Dave
Posted 22 October 2020 - 06:24 PM
Hello
I hava a 2002 Ford mondeo Estate with 2.0 Tddi
So lately i have issues with front camber.
The numbers are in green but rather close to the " red zone"
I wouldn`t really care but I think that is causing extra wear on the insides of the tyres
I went thru a set of fronts with this summer ( 10 000 km )
I put in a set of shock absorbers, new strut bearings and mounts, made it a bit better but still not near to perfect
I had an MOT place find mistakes from the front end, and the only thing they said was that i have a leaking middle muffler, but did mention that the camber is visibly off on the car.
The car hasnt been lowered or been in accidents, Toe was aligned and castor was perfect.
Im starting to think I ned to find some camber plates for the front end.
amyone here have any experience with those .. ?
#2 TreborB
TreborB
    Powershifts Forever
  • 5115 posts
  • Vehicle Driven:BMW 320i M Sport
  • Name:TrevorB
Posted 22 October 2020 - 09:15 PM
When you say the toe is within limits, what actually is it.
The allowance is from a toe out to a toe in setting, so, if it is zero or slightly toe out it is within tolerances, and theoretically ok.
BUT, with your situation I would set it to maximum toe in setting allowed
BMW 320i M Sport 2019 Mineral Grey, Steptronic 8 speed ZF Auto
( Sorry but NO 2.3 Ecoboost 8 Speed Auto Mondeo's to be found!)
Focus 2018 Mk3.5, 1 Litre Ecoboost 140ps ST Line, SYNC3 Sat Nav, Parking Sensors, Colour Magnetic - Gifted to the Wife! Then Sold Aug 2019
Mondeo Mk5 Titanium 2L Ecoboost 240ps, X Pack, Body Kit, Rear Spoiler, 19" Alloys, LED Headlamps, Sony 12 Spkr Audio, Park Assist, Winter Pack, Rear Camera, Magnetic, Built Sept 2015,Sold Oct 2018.
Mondeo TitaniumX Sport 240ps 2L Ecoboost Powershift 2011 - Sold 2016 But Never Forgotten.
2007 - 2010, 4 New Focus ST225s
#3 Tulejumal
Tulejumal
  • 57 posts
  • Name:Dave
Posted 27 October 2020 - 08:58 PM
I didn`t take the printout, The last time I changed the tyres, I know they adjusted the Toe because it can be done and it was a bit off, after that the steering wheel was straight and car didn`t pull anywhere.
This time around Toe was in the "Green"  but since i had the car up already i adjusted it a bit to make it as spot on as i could.
Camber in the front left is -1,06 deg
                                right is : -1,54 deg
Should be -1,56 to 0,37
I`ll try and get some time on the lift sometime soon to check if maybe we put the upper strut bushes on a bit wrong.
Turns out you can misaligne those and that might cause camber issues.
#4 TreborB
TreborB
    Powershifts Forever
  • 5115 posts
  • Name:TrevorB
Posted 28 October 2020 - 08:38 AM
The toe figures maybe in the "green" but that just means it is within Ford tolerances, so could be anywhere from toe out to toe in. That's why I asked for your actual toe figures
To help overcome your problem you need to make sure your veh is set to max toe in
#5 ST56
ST56
    Clever cloggs
  • 2056 posts
Posted 28 October 2020 - 01:29 PM
Hi
You do not mention replacing lower arms, while settings stationary are within specs any movement within bushes when under load will allow bottom of strut to move relative to car body. For example when braking struts will be pushed back while move forward when accelerating.
Peter
Edited by ST56, 28 October 2020 - 01:30 PM.
Previously Mondeo MK2 ST200.
Previously Sierra XR4x4.
#6 Tulejumal
Tulejumal
  • 57 posts
  • Name:Dave
Posted 16 November 2020 - 09:02 AM
The arms and bushes were good, as the MOT guy checked them up and found nothing wrong.
I ended up grinding the balljoint fixing holes, so that i could push the balljoint more in to the arm and that way get rid of the extra camber.
Car is sitting upright now and I hope this is the end for this issue.
#7 TreborB
TreborB
    Powershifts Forever
  • 5115 posts
  • Name:TrevorB
Posted 16 November 2020 - 10:01 AM
You have still not said what the toe figures were, and/or what you have adjusted the toe to now - waste of time people trying to help
