Duratorq 1.6 Engine Malfunction - Mechanical (Focus Mk3) - TalkFord.com
No replies to this topic
#1 Mason1982
Mason1982
  • 1 posts
  • Vehicle Driven:Focus 3.5 Diesel
  • Name:Rob Mason
Posted 16 October 2020 - 07:09 PM
Can anyone help here please?
Just before Christmas last year, I started to get intermittent engine malfunction warning with limp mode. This would happen when putting stress on the engine (usually on acceleration). I changed all filters (air/oil and fuel) and the issue seemed to go away.
Yesterday, the issue happened again twice. I have run a Forscan trace on the fuel rail pressure and it shows as consistently 300kPa short (actual vs desired). Can someone who knows better than me let me know if this is the likely cause. No DTCs present at all
Have also run the DPF pressure trace - can only get 1 reading - anyone know how many sensors my car should have? Booked in for a DPF maintenance clean tomorrow at Halfords (more in hope than expectation tbh) to see if that helps any.
Have only done about 2000 miles on the new filters due to lockdown.
