I've recently bought a 2012 Mondeo (1.6 TDCI 115 PS) and noticed water in the boot under the spare wheel.
The water is getting under the fuel cover (another problem) and I think it's going into the overflow hole below the fuel hole and into the boot. I can't be sure exactly without looking at it properly. Is there a pipe which could have come off the overflow or is it all self contained inside the fuel holster. I can't see anywhere else the water could be going.
Also, there is a gap at the top of the fuel filler cover. Can this be tightened or should I replace it? Replacing it looks like a tricky job.
Thanks.
