Tires for Ford S-max - Tyre Talk - TalkFord.com
3 replies to this topic
#1 Chresten
Chresten
  • 3 posts
  • Vehicle Driven:Mondeo MK4
  • Name:Chresten Jørgensen
Posted 06 October 2020 - 06:53 AM
Hi,
Just bought a Ford S-Max from 2017 (150HK, powershift) and are now looking for new rims and tires for the winter season.
I wonder what size of tires can work on the car ?
I´ve been told that it must be 235/55 R17, but as far as I can see it´s most common to use 16" tires for the winter season.
Any ideas or good websites to visit ?
Thanks a lot
BR
Chresten
#2 Master-of-none
Master-of-none
    Clever cloggs
  • 1563 posts
  • Vehicle Driven:1.0 125PS Focus Ti
Posted 06 October 2020 - 08:15 AM
You can download the owner's manual
https://www.ford.co....oad-your-manual
or
https://www.ford.dk/...-intruktionsbog
It lists the tyres/tires that are factory fitted
For 2017 they are:
235/55R17 (the only size permitted to fit snow chains)
235/50R18
245/45R19
T155/70R17 (emergency spare)
copied from here:
Perhaps you could test fit a 16" steel wheel, check if the brake calliper rubs.
  • TreborB likes this
Weaselling out of things is important to learn,it's what separates us from the animals Except the weasel
#3 Chresten
Chresten
  • 3 posts
Posted 06 October 2020 - 09:42 AM
Thank you Master-of-none!
I found the list in the manual but was in doubt if those are the only ones usable for the car.
Do you know if it´s OK to use 16" wheels as long as there is enough space for the caliper?
Any safety conditions to be aware of if not using the listed sizes ?
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28864 posts
Posted 06 October 2020 - 10:32 AM
No factory option for 16" wheels.  I dont have the PCD, bore and offset for the newer S-Max
to compare.
Most common to use 16" because they are usually cheaper.
Trip to the scrapyard assuming you have any open near you and an afternoon
checking what wheels may fit?
The shape of the wheel will also vary so one 16" may fit where many others may not.
