2008 mondeo diesel dashboard problem - Electrical (Mk4 Mondeo) - TalkFord.com
5 replies to this topic
#1 stevebs58
stevebs58
  • 1 posts
  • Vehicle Driven:mondeo 2.0tdci auto
  • Name:Steve Seeney
Posted 01 October 2020 - 02:00 PM
I am familiar with instrument cluster problems having already replaced one however I have a new problem that I am not sure if it is the cluster or not and have not been able to find an answer within the forums.
Whilst driving I experience intermittent total instrument power failure simultaneously with loss of display on the climate control and the steering wheel control illumination, this lasts from a few seconds up to a few minutes. the instruments lose all the dials digital screen and illumination and I also appear to lose the indicators although this may be just because the repeater on the dash and the audible click has also stopped working.
This seems more like a  power supply/canbus? problem.
I do not want to replace the instrument cluster again if the problem actually lies elsewhere. Does anyone have any experience of this issue or suggestions on how to diagnose without getting a garage to start replacing parts one by one.
I have also replaced the battery within the last 12 months.
#2 TheAntman
TheAntman
  • 59 posts
  • Vehicle Driven:Mondeo Sport
  • Name:Tony Ford
Posted 02 October 2020 - 08:02 AM
Sounds to me like you are having general connectivity issues. Could even be a connector somewhere not fully plugged in (I had something similar with another vehicle a few years ago. The stereo just died. When I took it out to inspect, I found that one of the connectors had come out)
#3 gjovano011
gjovano011
  • 5 posts
  • Vehicle Driven:Mondeo mk4. 1.8TDCi
  • Name:Goran
Posted 03 October 2020 - 09:06 AM
Hi,
Same problem on my mondeo MK4, 2009, 1.8TDCi,
my IPC (panel) and HVAC are dead. Car start regularly, everything works but no signalization.
I check CAN-bus resistance on OBDII connector, cca 150 Ohm. Correct is 60 Ohm.
Release IPC connector, CanBus resistance is 0 Ohm? Is this correct?
Pull connector again, "shake a little" connector on IPC and everything works fine.... but not for a long time. Problem persist. Car work good.
How can I find wiring diagram? Does anyone have idea what to do?
#4 mike4369
mike4369
  • 2995 posts
  • Vehicle Driven:2014 C Max 1.6TDCi
  • Name:Mike
Posted 03 October 2020 - 10:54 AM
Try dismantling the connector to check for corrosion or loose connection/ broken wire.
#5 gjovano011
gjovano011
  • 5 posts
  • Name:Goran
Posted 06 October 2020 - 09:26 AM
I
Ido this all. Dismount IPC, resolder all pin. Problem persist.
I check Pinpoint test AI (PINPOINT TEST AI : FAULTY COMMUNICATIONS BETWEEN THE MODULES - MM CAN BUS), and must to "LOCATE and RECTIFY the break in circuit VDB14F (VT/GY) between soldered connection SP353 and DLC with the aid of the the Wiring Diagrams. CHECK system operates correctly".
I do not know where is SP353 (and SP348), please if somebody know position of this SP I would be grateful.
#6 gjovano011
gjovano011
  • 5 posts
  • Name:Goran
Posted 17 October 2020 - 07:16 PM
Any idea?
