Hi All,
So I have a 2014 transit custom 2.2, the EGR was changed 3 weeks ago due to the old one being stuck open.
Since then all was well until 3 days ago, I now have an EML and when plugged in I am getting the following:
PCM - P0405 - EGR Sensor Circuit Low
PCM - P0674 - Cylinder 4 Glow Plug Circuit / Open
PCM - P037D - Glow Plug Sense Circuit
PCM - P1303 - EGR Calibration Fault
PCM - P244C - Exhaust Temperature Too Low For Particulate Filter Regeneration , Bank 1
PCM - P246C - Particulate Filter Restriction - Forced Limited Power (Bank 1)
PCM - P2463 - Particulate Filter Restriction
I attempted a static regeneration but it failed at 18%.
Question is would a Vaporizer fault cause the majority of these codes ??
And would the glow plug fault also cause the system not to regenerate ??
Any thoughts on the way forward would be much appreciated.
Huckster522 has posted in PAS fluid Headache conundrum in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Today, 08:12 AM
ORYX has posted in After installed sat nav, front/ rear sensor not work in In-Car Entertainment (Mk4 Mondeo).
Today, 07:28 AM
PURPLE_2L_LX has posted in PAS fluid Headache conundrum in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Today, 05:54 AM
PURPLE_2L_LX has posted in Am I really supposed to be embarressed here talking about myself? in New Members Welcome Area.
Today, 05:48 AM
Ufkun88 has started Am I really supposed to be embarressed here talking about myself? in New Members Welcome Area.
Yesterday, 11:41 PM
DPF Soot Accumulation
Started by
TRUCKERT
, Sep 28 2020 10:39 AM
1 reply to this topic
#1
Posted 28 September 2020 - 10:39 AM
#2
Posted 28 September 2020 - 10:53 AM
I would suggest getting the vaporiser replaced, common issue on the Customs. (from what I've read on the Custom Owner Group on Facebook) Should be the same unit as in my Mondeo.
Don't know about the other codes and if they're related, though cylinder 4 glow plug circuit / open suggests it's disconnected in some way, be it unplugged, corrosion in the multiplug, broken wire etc. so check that and read the codes again.
Mondeo 2.2 TDCI Titanium X Sport (MK4.5), Panther Black | S-Max 2.5T front brake calipers and 316mm discs | Fuel Log
Now Dead - Mondeo ST24, 2000 W reg, Amparo Blue | ST170 Calipers and Discs | Goodridge Hoses | GW Decat | K&N Panel Filter | Black eyes | LPG
Honda Hornet, 2004, Matt Blue.
