Heating randomly comes on - Ford Ka Mk1 Forum (1996-2008) - TalkFord.com
No replies to this topic
#1 Jayjay91
Jayjay91
  • 2 posts
  • Vehicle Driven:Ka
  • Name:Jamie ayre
Posted 26 September 2020 - 03:08 PM
Hi guys and girls,
I bought a mk1 ka for my wifes first car 07. The heating wouldn't work. Replaced the heater control valve as it appears to ve common. Also replaced the thermostat and expansion tank. If I do a single journey it heating will stay off but if I switch it off for a few mins to pop in the shop or turn the heating up slightly, the heat is like lava. I have put a multi meter at the hcv it pulses when half way and steady when set on hot or cold. According to the obd scanner the temps are all normal and the cooling fan cuts in when it should etc. Any ideas on what to check next.
