2006 2.2 tdci 6th gear problem - Transmission / Drivetrain (Mondeo Mk3) - TalkFord.com
4 replies to this topic
#1 markkp
markkp
  • 2 posts
  • Vehicle Driven:Ford Mondeo 2006
  • Name:Mark P
Posted 25 September 2020 - 09:50 PM
Hi, my 2006 2.2 tdci 114kw Mondeo estate has a gearbox failure - if I try to shift into 6th gear, it goes into 4th. It does not matter whether I’m driving or try to shift gears while stationary and the car is turned off, 6th gear is missing. Anyone experienced the same, how could I fix this?
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28562 posts
Posted 26 September 2020 - 05:18 PM
Did it work previously or did you buy it like that?
Possibly just needs the cables adjusting, may need a good pull to the right to
engage 6th.
Worst case it needs a new gearbox.
#3 Communist
Communist
    Mk3 4 LYFE
  • 277 posts
  • Vehicle Driven:2005 Mondeo 1.8
  • Name:Karl Marx
Posted 27 September 2020 - 06:42 PM
Get someone sitting in the car to go through the gears, then watch the shift mechanism on the top of the gearbox. If it looks like it's doing exactly the same thing selecting 6th as it does 4th, then that needs more investigation.
I would certainly start there and with the cables. Could be a load of crap has got in there and is stopping the selector from moving far enough.
Edited by Communist, 27 September 2020 - 06:43 PM.
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28562 posts
Posted 28 September 2020 - 02:08 AM
Every time i see your user name i think of Borsch (Borscht)? and Comrade Dad.
He could only dream of a Mondeo though having to make do with a Skrover?
Skoda/Rover welded together, never could find that episode though.
Wanting to change your MK3 4 LYFE to  Borsch(t) for life comrade.
#5 markkp
markkp
  • 2 posts
  • Name:Mark P
Posted 30 September 2020 - 07:11 PM
I actually managed to engage the 6th gear. I have to shift from 5th gear to 6th and hold the shifter quite hard to the right edge and push it down with a fair bit of force. I will look in to the cables and hopefully by adjusting them it will be fine.
