2017 Kuga Aux/lighter sockets - Ford Kuga Forum - TalkFord.com
4 replies to this topic
#1 turbopete1
turbopete1
    TF regular
  • 583 posts
  • Vehicle Driven:mk4 mondeo zetec
  • Name:Peter
Posted 21 September 2020 - 06:50 PM
hi.
Not my car so please bear with me. a friend has just collected a 2017 Kuga today. they have a dashcam which they DONT want hard wired. I assumed it would be like my Mondeo where you get out of the car, lock it, walk away and everything shuts off after 20 mins or so. they have been out to the car after around 25 mins and the lighter socket is still live. is this normal? theyre plugging it into the lighter socket behind the gearstick, near the EPB switch area.
is there one that shuts off with the ignition/when the car shuts off? it saves the trouble of risking it flattening the battery or being forgot to be plugged in!
any help greatfully accepted.
Thanks in advance
Edited by turbopete1, 21 September 2020 - 06:56 PM.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29202 posts
Posted 21 September 2020 - 10:34 PM
Did they walk upto the car with the keys/fob by any chance? It would have
unlocked and activated the socket again.
Have they checked the fusebox to see if its a dual slot like some other fords?
3 pins, one pin live with the ignition, one live 24/7. Probably need to leave it
longer than 20 minutes. Takes a little while for everything to turn off before the
battery saver kicks in and times 20 minutes.
AC fans can spin after the engine is off on some cars and the heater flaps can
move also.
#3 turbopete1
turbopete1
    TF regular
  • 583 posts
  • Name:Peter
Posted 22 September 2020 - 10:39 AM
no they left the keys in the house to check, and im 99% certain (as dad has an identical 2019 car) that you have to grab the handle to unlock it etc anyhow.
theyre not mechanically minded and literally only collected the car at 11am yesterday so they havent had much chance to look around. there does seem to be conflicting info as some sources say the sockets are wired direct to the battery via the fuse, but the odd one or 2 say they go off after around 15-20 mins.
i know the heater flaps move on the mondeo as i hear them regularly on my car, but never stayed in a kuga long enough. i will have to look at the fuses possibly (or they may opt to live with the idea that they stay on permanently as most sources seem to claim) at some point when i find the appropriate fuses/fusebox to chack. presumably its a case of moving the fuse from 1 set of slots to the other if they do have ignition feed/permanent feed options?
#4 mike4369
mike4369
  • 3015 posts
  • Vehicle Driven:2014 C Max 1.6TDCi
  • Name:Mike
Posted 22 September 2020 - 01:18 PM
The manual is not specific as to the power being live for a period after switching off but in all the Fords I've had the aux socket goes off after 15-20 mins. My dash cam is plugged into one and that goes off as stated and I've not had any problems with a flat battery so far.
Edited by mike4369, 22 September 2020 - 01:28 PM.
#5 turbopete1
turbopete1
    TF regular
  • 583 posts
  • Name:Peter
Posted 22 September 2020 - 03:44 PM
this one was left for more than long enough to shut down. my Mondeo would have shut down well before that time. 20 mins used to be the norm for the mondeo (its gone down a bit since is battery old now, possibly the original to the car) so id assume that the Kuga would be similar, and it was left for a generous 25 mins.
