strange sound - Diesel Engines (Mondeo Mk3) - TalkFord.com
strange sound
2 replies to this topic
#1 gabyh
gabyh
  • 7 posts
Posted 20 September 2020 - 06:52 PM
Hy
I have this problem with my car, ..a strange sound from injectors zone like this
It's a injector block or open problem?
In the past when i have problems like these i changed the imv valve from back of high pump and sound dissapear but after 2/3 months sound appeared.
No errors on my Icarsoft i920 tester
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28556 posts
Posted 20 September 2020 - 06:58 PM
Thats one sick puppy.  Unplug the electrical plug to one injector at a time and
see if the noise stops. Its likely to cut out fairly quickly so probably a small time
to catch whether the noise stops.
You may find one injector wont make as much difference to the running compared
to teh others.
A leakoff test maybe a worthwhile also.
#3 gabyh
gabyh
  • 7 posts
Posted 20 September 2020 - 07:38 PM
In the past when i had same problem ..i had big leaks..from every injectors..i have a leak test kit..i will try to disconect the electric plug from injectors
Edited by gabyh, 20 September 2020 - 07:39 PM.
