Hi,
Can anyone advise where the engine temp sensor(s) are located on the 2.0 Duratec please? I'm not sure if there's a single one or more than that.
The reason I ask is that the temp gauge in the instrument cluster never moves position. It's the Mk4.5 - so it's hidden in one of the menus. It always shows the same, even when stone cold or hot. I know that in some cars there is one sensor for the ECU and another for the cluster & im not sure which the Mondeo uses.
Thanks - Rob
Thanks - Rob
