Squealing noise when air con is on - Air-Con / Heating (Mk3 Mondeo) - TalkFord.com
3 replies to this topic
#1 Jbarret
Jbarret
  • 3 posts
  • Vehicle Driven:Ford Mondeo M3
  • Name:Ms Julie A Barrett
Posted 14 September 2020 - 07:40 PM
I have a Ford Mondeo M3 2006 - My aircon squeals when it's turned on. It appears to be intermittent. When its on full blast, the noise stops.
I had it recharged a couple of days ago and it seems to of gotten worse since then. Any ideas?
Edited by Jbarret, 14 September 2020 - 07:43 PM.
#2 Communist
Communist
    Mk3 4 LYFE
  • 261 posts
  • Vehicle Driven:2005 Mondeo 1.8
  • Name:Karl Marx
Posted 15 September 2020 - 09:53 PM
Is this a squealing from the engine bay or from the interior of the car? Does the noise only happen when the climate control says AC or does it also happen if you press the AC button so it says ECO?
If it's from the interior on the passenger side, then the blower fan needs looking at. It's very easy to get it out, there is a piece of matting underneath the glovebox. Pull that down, then there are three torx screws. The fan drops straight out. You do not need to remove the glovebox, despite what the haynes manual says! Check the fan moves nice and smoothly, maybe lubricate it. Replacing it with one from a scrapyard is another option, they don't cost much.
If it's the engine bay then it'll be the compressor or the belt. Do you get the noise if you run the engine and turn on the heated screens and headlights?
Edited by Communist, 15 September 2020 - 09:56 PM.
#3 Jbarret
Jbarret
  • 3 posts
Posted 17 September 2020 - 12:12 PM
Hi,
I'd say it was the interior on the passenger side. So ill try the blower fan and let you know how I get on.
Thank you!!!
#4 Jbarret
Jbarret
  • 3 posts
Posted 19 September 2020 - 10:16 AM
Lube worked a treat! No more noise.
Thanks 😊
