auto gear box slipping when accelerating - Transmission / Drivetrain (Mondeo Mk3) - TalkFord.com
clutch slipping gearbox slipping mondeo mk3 2003 auto
5 replies to this topic
#1 bacchus
bacchus
  • 58 posts
  • Vehicle Driven:mondeo 2002 diesel
  • Name:greg
Posted 14 September 2020 - 09:25 AM
Hi all
Apologies if this has been answered before, but I'd ask anyways. The clutch is slipping when I accelerate. Example, when I'm going about 60 on the motorway and I take my foot off the accelerator pedal and then try to accelerate again, it slips for a bit before engaging the gear. Normally when I'm driving slower, say around 30-40 mph, it seems fine, just when going faster. Does this mean a new clutch? apologies for my poor description.
Edited by bacchus, 14 September 2020 - 09:26 AM.
Mondeo ZTEC 2003, 2L Petrol, Auto
140,000k Miles, RJ03ZFN
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28556 posts
Posted 14 September 2020 - 10:58 PM
Not as easy to say with an automatic gearbox.
Often they have several clutches which may only affect certain gears.
Low fluid level could cause change issues, incorrect fluid can cause change issues.
When was the gearbox last serviced?
Possibly the same oil since it left the factory.
Valve blocks within the gearbox could also be the cause.
#3 bacchus
bacchus
  • 58 posts
  • Name:greg
Posted 15 September 2020 - 07:53 PM
well I've had the car for about 4 years and haven't changed the fluid yet. And I know it's over filled as well. Am planning on changing the fluid this week, so will see how that goes.
Cheers
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28556 posts
Posted 15 September 2020 - 08:56 PM
Over 8 litres of oil in it normally for a change, make sure you drain the
gearbox oil cooler also.
How much over maximum is it?  I would have a container between 15 and 20 litres
just in case.
Normally it would be closer to 10 litres if you leave it draining for a while.
And warning lights or fault codes for the transmission?
#5 Communist
Communist
    Mk3 4 LYFE
  • 277 posts
  • Vehicle Driven:2005 Mondeo 1.8
  • Name:Karl Marx
Posted 18 September 2020 - 10:31 PM
Changing ATF once it's very old and the box has already started slipping usually makes it worse. An auto slush box doesn't have a clutch like a manual one does, it's a box filled with small clutches! If the clutches are very worn then all that might be allowing them to bite is the worn off friction material floating around in the oil! If you remove that then they wont be able to bite at all and all you'll have is slip.
If it's so bad the car is almost undrivable, or you can live without it, then you've got nothing to lose by trying to change the oil, but otherwise i'd leave it alone and keep driving it while you sort out another box for it.
Prevention is better than cure with this type of thing. More frequent changes would have slowed down the rate of wear earlier on.
#6 bacchus
bacchus
  • 58 posts
  • Name:greg
Posted 20 September 2020 - 07:19 PM
Hey communist, thanks for the advice. It’s not really bad so I can live with it for now.
Also tagged with one or more of these keywords: clutch slipping, gearbox slipping, mondeo mk3 2003 auto
