1.6 tdci power stutter - Diesel Engines (Mk4 Mondeo) - TalkFord.com
1 reply to this topic
#1 Branzino
Branzino
  • 16 posts
  • Vehicle Driven:mONDEO
Posted 13 August 2020 - 12:03 AM
Hi
I have a 2011 1.6 tdci that's experiencing intermittent power loss 5-20 mins after starting. Fault code p062d is occurring which is cylinder 1.
I suspect its an intermittent electrical connection to this injector associated with the wiring loom but realise  it could be the injector itself either.
Is there a way to test before I buy anything?
Thanks in advnace
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28471 posts
Posted 14 August 2020 - 06:43 PM
Cleanup the connectors with some contact cleaner and plug it in
and out a few times whilst spraying it with the contact cleaner.
If that fails try a known good used injector, or swap the injector from cylinder 1 to 2
and see if the fault moves with the injector or stays with the cylinder.
