Central hight mounted brake lamp - Ford S-Max Forum - TalkFord.com
3 replies to this topic
#1 SimonB39
SimonB39
  • 8 posts
  • Vehicle Driven:Ford smax 2007
  • Name:Simas Barzdonis
Posted 30 July 2020 - 08:22 PM
Hi. My central hight mounted brake lamp is not working. Bulb and fuses are ok. What can be?
#2 rbitton782
rbitton782
  • 116 posts
Posted 30 July 2020 - 09:27 PM
GW
Check with voltmeter, if there is 12 volts in the connector.
Sent from my SM-G950F using Tapatalk
#3 SimonB39
SimonB39
  • 8 posts
Posted 31 July 2020 - 07:23 AM
No there is no power coming to socket
#4 rbitton782
rbitton782
  • 116 posts
Posted 31 July 2020 - 08:53 AM
GW
Check on the fuse, if OK check the dynamic harness that runs from the rear door to the car, how?, connect voltmeter to the connector at the same time start bending the harness and see for any results.
P.s: don't forget someone pressing the brake pedal at the same time.
