The chrome is peeling off on the chrome strip fitted to the tailgate handle.Is it possible to replace this..I also need to replace the microswitch on the tailgate release as it only seems to work on the right hand side of the rubber cover..the release button was very sensitive on my last mk3 estate so that is how I want this one to be.
PURPLE_2L_LX has posted in Fitting new bumper clips - technique? in Interior / Exterior (Ka Mk1) .
Today, 12:49 AM
PURPLE_2L_LX has posted in Turbo replacement (parts needed) in Diesel Engines (Mk4 Mondeo).
Today, 12:43 AM
PURPLE_2L_LX has posted in Whining noise when at full temp and other issues - 2010 mondeo 2.0tdci in Diesel Engines (Mk4 Mondeo).
Today, 12:31 AM
bobalong has started Whining noise when at full temp and other issues - 2010 mondeo 2.0tdci in Diesel Engines (Mk4 Mondeo).
Yesterday, 10:01 PM
Estate tailgate chrome strip on handle.
Started by
philmartin
, Jul 11 2020 08:27 AM
estate tailgate chrome strip on handle.
2 replies to this topic
#1
Posted 11 July 2020 - 08:27 AM
#2
Posted 11 July 2020 - 11:33 AM
Depending on what colour your estate is it might just be easier and cheaper to replace the entire handle.
You can put your vehicle info at the bottom of your posts to give details to help others know what you drive
#3
Posted 19 October 2020 - 09:38 PM
yes, the chrome bit is removable, it's just clipped on
as for the boot button, it means a strip out of the handle to change, i should have taken pics as i did this only yesterday to change the number plate light loom as it had got trapped when i pulled it
if you are still looking months and months later then this is how you do it
inside the pull down handles there is a screw per side, unscrew this
then you (don't have to but it is much easier to do it this way than fiddle with the big cover) have to remove the center brake light, 2 screws, and then pull the plastic window surrounds off, they are clipped into place and require "force"
you can now apply lots of pulling pressure to the edges of the big black cover, it's got 10 or 12 different push fit metal clips and, if you are unlucky, one of them will snap as you pull it off
you also have to prise the boot closed rubber holes on either side over the stops
at this point it's best practice to remove the number plate light screws and unplug the wiring from the bck of them, they will need careful prising out as the rubber is very stick so as to not let water into the boot lid
once everything is out you can then see the 4 10mm nuts that hold the panel in place
the inner 2 nuts have metal panels on them for the wiring and as you look upwards to them the center right nut is fouled by the wiper motor bracket
you can undo this though but it's very very fiddly
pull the number plate loom out of the way now and unplug the switch
now the panel simply pops out
swap stuff over and refit, making sure that those screws in the grab handles are fully aligned up, the spring clips need careful and forceful banging back into place so make sure you line things up, this is why you have to remove the surround panels otherwise it becomes a bit of a contortion to get things back into place again, yo can do it, but it's more hassle than it's worth
mk3 mondeo ghia x estate 2.0 auto with:
362mm 6 pot ap stoppers lurking behind some 8 x 18 comps
tv fitted to facelifted dash + headrest screens for both kids
full st kit + powerfolds w/puddlelights with jp stainless exhaust
shonky n/s/f rattle fixed by totd whoopie!
most of the chrome bits done
Also tagged with one or more of these keywords: estate, tailgate, chrome strip on handle.
