How to remove the coil pack—-under the engine - Ford Ka Mk1 Forum (1996-2008) - TalkFord.com
1 reply to this topic
#1 Kenchi
Kenchi
  • 1 posts
  • Vehicle Driven:Ford KA
  • Name:Kenneth Chibata
Posted 26 June 2020 - 04:58 PM
Can anyone help with the easiest way of removing the coil pack that is behind the fuel system. What kind of screws bolts it down. It is very hard to see or reach. I am not sure what to remove to get to it easily.
Edited by Kenchi, 26 June 2020 - 05:22 PM.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28204 posts
Posted 30 June 2020 - 12:45 AM
Guessing its not the Duratec engine?  right hand side at the rear 4 torx bolts T25/T27?
Older pre-2002 (ish) car. Choices choices..  Remove quite a lot from the top and have easier
access or if you have 5 finger joints and 3 wrists and flexible arms from under the car. Yep
silly place to hide it under the manifold.
And yep under the car is probably easier if you have the tools to do that.
Should be Torz drive also T25/27 or T30?   A common size that comes with most screwdriver kits.
Small 1/4" ratchet with some extension bars and flexible drives maybe useful.
